Thanks for your help,
his the new log as you want
12:10:58 pptp,ppp,debug <2**...7>: PPP connected
12:10:58 pptp,ppp,debug <2...7>: LCP lowerup
12:10:58 pptp,ppp,debug <2...7>: LCP open
12:10:58 pptp,debug,packet sent Outgoing-Call-Reply to 2...7
12:10:58 pptp,debug,packet call-id=383
12:10:58 pptp,debug,packet peers-call-id=1591
12:10:58 pptp,debug,packet result-code=1
12:10:58 pptp,debug,packet error-code=0
12:10:58 pptp,debug,packet cause-code=0
12:10:58 pptp,debug,packet connect-speed=100000
12:10:58 pptp,debug,packet packet-recv-window-size=100
12:10:58 pptp,debug,packet packet-processing-delay=0
12:10:58 pptp,debug,packet physical-channel-id=0
12:10:59 pptp,ppp,debug <2...7>: LCP timer
12:10:59 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x1
12:10:59 pptp,ppp,debug,packet <mru 1460>
12:10:59 pptp,ppp,debug,packet <magic 0x1b46a9f3>
12:11:00 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfReq id=0x97
12:11:00 pptp,ppp,debug,packet <mru 1460>
12:11:00 pptp,ppp,debug,packet <magic 0x11c061f3>
12:11:00 pptp,ppp,debug,packet <2...7>: sent LCP ConfAck id=0x97
12:11:00 pptp,ppp,debug <2...7>: LCP timer
12:11:00 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x2
12:11:00 pptp,ppp,debug,packet <magic 0x1b46a9f3>
12:11:00 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfAck id=0x1
12:11:00 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfReq id=0x98
12:11:00 pptp,ppp,debug,packet <2...7>: sent LCP ConfAck id=0x98
12:11:01 pptp,ppp,debug <2...7>: LCP timer
12:11:01 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x3
12:11:01 pptp,ppp,debug,packet <mru 1460>
12:11:01 pptp,ppp,debug,packet <magic 0x1b46a9f3>
12:11:02 pptp,ppp,debug <2...7>: LCP timer
12:11:02 pptp,ppp,debug <2...7>: LCP timeout sending ConfReq
12:11:02 pptp,ppp,debug <2...7>: LCP lowerdown
12:11:02 pptp,ppp,info : terminating…
12:11:02 pptp,ppp,debug <2...7>: PPP disconnected <>
12:11:02 pptp,ppp,debug <2...7>: PPP destroy
12:11:02 pptp,ppp,debug <2...7>: PPP stopped
12:11:02 pptp,ppp,info : disconnected
12:11:02 pptp,ppp,debug <2...7>: CCP lowerdown
12:11:02 pptp,ppp,debug <2...7>: CCP down event in initial state
12:11:02 pptp,ppp,debug <2...7>: IPCP lowerdown
12:11:02 pptp,ppp,debug <2...7>: IPCP down event in initial state
12:11:14 pptp,info TCP connection established from 2...7
12:11:14 pptp,ppp,debug <2...7>: PPP started
12:11:14 pptp,ppp,info : waiting for call…
12:11:14 pptp,debug,packet rcvd Start-Control-Connection-Request from
2...7
12:11:14 pptp,debug,packet protocol-version=0x0100
12:11:14 pptp,debug,packet framing-capabilities=2
12:11:14 pptp,debug,packet bearer-capabilities=0
12:11:14 pptp,debug,packet maximum-channels=0
12:11:14 pptp,debug,packet firmware-revision=1
12:11:14 pptp,debug,packet host-name=HOST
12:11:14 pptp,debug,packet vendor-name=MikroTik
12:11:14 pptp,debug,packet sent Start-Control-Connection-Reply to
2...7
12:11:14 pptp,debug,packet result-code=1
12:11:14 pptp,debug,packet error-code=0
12:11:16 pptp,debug,packet rcvd Outgoing-Call-Request from 2...7
12:11:16 pptp,debug,packet call-id=1592
12:11:16 pptp,debug,packet call-serial-number=0
12:11:16 pptp,debug,packet minimum-bps=2400
12:11:16 pptp,debug,packet maximum-bps=10000000
12:11:16 pptp,debug,packet bearer-type=3
12:11:16 pptp,debug,packet framing-type=2
12:11:16 pptp,debug,packet packet-recv-window-size=100
12:11:16 pptp,debug,packet packet-processing-delay=0
12:11:16 pptp,debug,packet phone-number-length=0
12:11:16 pptp,debug,packet phone-number=
12:11:16 pptp,debug,packet subaddress=
12:11:16 pptp,ppp,debug <2...7>: PPP connected
12:11:16 pptp,ppp,debug <2...7>: LCP lowerup
12:11:16 pptp,ppp,debug <2...7>: LCP open
12:11:16 pptp,debug,packet sent Outgoing-Call-Reply to 2...7
12:11:16 pptp,debug,packet call-id=384
12:11:16 pptp,debug,packet peers-call-id=1592
12:11:16 pptp,debug,packet result-code=1
12:11:16 pptp,debug,packet error-code=0
12:11:16 pptp,debug,packet cause-code=0
12:11:16 pptp,debug,packet connect-speed=100000
12:11:16 pptp,debug,packet physical-channel-id=0
12:11:17 pptp,ppp,debug <2...7>: LCP timer
12:11:17 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x1
12:11:17 pptp,ppp,debug,packet <mru 1460>
12:11:17 pptp,ppp,debug,packet <magic 0x27ad79a9>
12:11:18 pptp,ppp,debug <2...7>: LCP timer
12:11:18 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x2
12:11:18 pptp,ppp,debug,packet <mru 1460>
12:11:18 pptp,ppp,debug,packet <magic 0x27ad79a9>
12:11:18 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfReq id=0x9c
12:11:18 pptp,ppp,debug,packet <magic 0x3446ea3e>
12:11:18 pptp,ppp,debug,packet <2...7>: sent LCP ConfAck id=0x9c
12:11:19 pptp,ppp,debug <2...7>: LCP timer
12:11:19 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x3
12:11:19 pptp,ppp,debug,packet <mru 1460>
12:11:19 pptp,ppp,debug,packet <magic 0x27ad79a9>
12:11:19 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfReq id=0x9d
12:11:19 pptp,ppp,debug,packet <magic 0x3446ea3e>
12:11:19 pptp,ppp,debug,packet <2...7>: sent LCP ConfAck id=0x9d
12:11:20 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfAck id=0x1
12:11:20 pptp,ppp,debug,packet <mru 1460>
12:11:20 pptp,ppp,debug,packet <magic 0x27ad79a9>
12:11:20 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfAck id=0x2
12:11:20 pptp,ppp,debug <2...7>: LCP timer
12:11:20 pptp,ppp,debug <2...7>: LCP timeout sending ConfReq
12:11:20 pptp,ppp,debug <2...7>: LCP lowerdown
12:11:20 pptp,ppp,info : terminating…
12:11:20 pptp,ppp,debug <2...7>: PPP disconnected <>
12:11:20 pptp,ppp,debug <2...7>: PPP destroy
12:11:20 pptp,ppp,debug <2...7>: PPP stopped
12:11:20 pptp,ppp,info : disconnected
12:11:20 pptp,ppp,debug <2...7>: CCP lowerdown
12:11:20 pptp,ppp,debug <2...7>: CCP down event in initial state
12:11:20 pptp,ppp,debug <2...7>: IPCP lowerdown
12:11:20 pptp,ppp,debug <2...7>: IPCP down event in initial state
12:11:32 pptp,info TCP connection established from 2...7
12:11:32 pptp,ppp,debug <2...7>: PPP started
12:11:32 pptp,ppp,info : waiting for call…
12:11:32 pptp,debug,packet rcvd Start-Control-Connection-Request from
2...7
12:11:32 pptp,debug,packet protocol-version=0x0100
12:11:32 pptp,debug,packet framing-capabilities=2
12:11:32 pptp,debug,packet bearer-capabilities=0
12:11:32 pptp,debug,packet maximum-channels=0
12:11:32 pptp,debug,packet firmware-revision=1
12:11:32 pptp,debug,packet host-name=HOST
12:11:32 pptp,debug,packet vendor-name=MikroTik
12:11:32 pptp,debug,packet sent Start-Control-Connection-Reply to
2...7
12:11:32 pptp,debug,packet result-code=1
12:11:32 pptp,debug,packet error-code=0
12:11:35 pptp,debug,packet rcvd Outgoing-Call-Request from 2...7
12:11:35 pptp,debug,packet call-id=1593
12:11:35 pptp,debug,packet call-serial-number=0
12:11:35 pptp,debug,packet minimum-bps=2400
12:11:35 pptp,debug,packet maximum-bps=10000000
12:11:35 pptp,debug,packet bearer-type=3
12:11:35 pptp,debug,packet framing-type=2
12:11:35 pptp,debug,packet packet-recv-window-size=100
12:11:35 pptp,debug,packet packet-processing-delay=0
12:11:35 pptp,debug,packet phone-number-length=0
12:11:35 pptp,debug,packet phone-number=
12:11:35 pptp,debug,packet subaddress=
12:11:35 pptp,ppp,debug <2...7>: PPP connected
12:11:35 pptp,ppp,debug <2...7>: LCP lowerup
12:11:35 pptp,ppp,debug <2...7>: LCP open
12:11:35 pptp,debug,packet sent Outgoing-Call-Reply to 2...7
12:11:35 pptp,debug,packet call-id=385
12:11:35 pptp,debug,packet peers-call-id=1593
12:11:35 pptp,debug,packet result-code=1
12:11:35 pptp,debug,packet error-code=0
12:11:35 pptp,debug,packet cause-code=0
12:11:35 pptp,debug,packet connect-speed=100000
12:11:35 pptp,debug,packet physical-channel-id=0
12:11:36 pptp,ppp,debug <2...7>: LCP timer
12:11:36 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x1
12:11:36 pptp,ppp,debug,packet <mru 1460>
12:11:36 pptp,ppp,debug,packet <magic 0x7ab94c9d>
12:11:37 pptp,ppp,debug <2...7>: LCP timer
12:11:37 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x2
12:11:37 pptp,ppp,debug,packet <mru 1460>
12:11:37 pptp,ppp,debug,packet <magic 0x7ab94c9d>
12:11:38 pptp,ppp,debug <2...7>: LCP timer
12:11:38 pptp,ppp,debug,packet <2...7>: sent LCP ConfReq id=0x3
12:11:38 pptp,ppp,debug,packet <mru 1460>
12:11:38 pptp,ppp,debug,packet <magic 0x7ab94c9d>
12:11:38 pptp,ppp,debug,packet <2...7>: rcvd LCP ConfReq id=0xa0
12:11:38 pptp,ppp,debug,packet <magic 0x19e5d4d7>
12:11:38 pptp,ppp,debug,packet <2...7>: sent LCP ConfAck id=0xa0
12:11:39 pptp,ppp,debug <2...7>: LCP timer
12:11:39 pptp,ppp,debug <2...7>: LCP timeout sending ConfReq
12:11:39 pptp,ppp,debug <2...7>: LCP lowerdown
12:11:39 pptp,ppp,info : terminating…
12:11:39 pptp,ppp,debug <2...7>: PPP disconnected <>
12:11:39 pptp,ppp,debug <2...7>: PPP destroy
12:11:39 pptp,ppp,debug <2...7>: PPP stopped
12:11:39 pptp,ppp,info : disconnected
12:11:39 pptp,ppp,debug <2...7>: CCP lowerdown
12:11:39 pptp,ppp,debug <2...7>: CCP down event in initial state
12:11:39 pptp,ppp,debug <2...7>: IPCP lowerdown
12:11:39 pptp,ppp,debug <2...7>: IPCP down event in initial state
12:11:54 pptp,info TCP connection established from 2...7
12:11:54 pptp,ppp,debug <2...7>: PPP started
12:11:54 pptp,ppp,info : waiting for call…
12:11:54 pptp,debug,packet rcvd Start-Control-Connection-Request from
2...7
12:11:54 pptp,debug,packet protocol-version=0x0100
12:11:54 pptp,debug,packet framing-capabilities=2
12:11:54 pptp,debug,packet bearer-capabilities=0
12:11:54 pptp,debug,packet maximum-channels=0
12:11:54 pptp,debug,packet firmware-revision=1
12:11:54 pptp,debug,packet host-name=HOST
12:11:54 pptp,debug,packet vendor-name=MikroTik
12:11:54 pptp,debug,packet sent Start-Control-Connection-Reply to
2...7
12:11:54 pptp,debug,packet result-code=1
12:11:54 pptp,debug,packet error-code=0
12:11:58 pptp,debug,packet rcvd Outgoing-Call-Request from 2..**.**7
12:11:58 pptp,debug,packet call-id=1594
12:11:58 pptp,debug,packet call-serial-number=0
12:11:58 pptp,debug,packet minimum-bps=2400
12:11:58 pptp,debug,packet maximum-bps=10000000
12:11:58 pptp,debug,packet bearer-type=3
12:11:58 pptp,debug,packet framing-type=2
12:11:58 pptp,debug,packet packet-recv-window-size=100
12:11:58 pptp,debug,packet packet-processing-delay=0
12:11:58 pptp,debug,packet phone-number-length=0
12:11:58 pptp,debug,packet phone-number=
12:11:58 pptp,debug,packet subaddress=
