I have set up three AP’s (133) within a medium village and they are all working on the 2.4Ghz frequency range, two of the AP’s can ‘See’ each other but the third is isolated.
I have multiple clients (133c) connected to each of these and i am experiencing problems with one of the AP’s that can see the other one, i am getting a maximum of 1M TX at the AP end, but the RX is showing anywhere up to 54M, when i connect my laptop to the AP i was getting anywhere between 24M either way and upwards, (i was the closest with my laptop to the AP).
I thought that the problem may have been the AP, so i have completely swapped out the kit and i am still getting the same results, i have turned off the DFS, so it cannot be interference from any other sources and i have scanned for any local 2.4Ghz frequencies that may be also interfering, but i have ample room on the spectrum.
I thought that the problem may have been the AP as the problem is common to the three 133c’s that i have hanging from the AP, but the kit swap seems to have made it just the same.
Any help would be appreciated.
Thanks,
Jamie
