Hello we are in the middle of a new network project which has 3 stages. I am having a problem setting up bridge links using 1xRB600 and 2x RB433 Units with 3x AR5413 Radios in each.
Please can someone look at my config below and see if you can see what I have done wrong, as i cant get them to link.
Stage 1:
Create a Bridge link to a local town with RB600 WAN2 and 1x RB433 WAN2.
Stage 2:
Create an AP using the RB433 Radio WLAN1 for clients.
Stage 3:
Create Bridge link to RB600 WAN3 to another RB433 on WAN1
We have the RB600 currently only being used as a AP. However we would like to use the other two radios for the new project.
This is the config for the RB600
WLAN1x is used for the AP for the local town (Working Pefectly)
WLAN2x is Bridge to Calasparra (Not Functioning)
WLAN3x is Bridge to office (Not Functioning)
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; added by setup
192.168.0.33/24 192.168.0.0 192.168.0.255 ether1
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:26:8A:F1 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid="MikroTik"
frequency=5680 band=5ghz scan-list=default antenna-mode=ant-a
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
default-authentication=no default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
compression=no
1 name="wlan2" mtu=1500 mac-address=00:0C:42:26:8A:FD arp=enabled
interface-type=Atheros AR5413 mode=bridge ssid="BridgetoCalasparra"
frequency=5640 band=5ghz scan-list=default antenna-mode=ant-a
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
compression=no
2 name="wlan3" mtu=1500 mac-address=00:0C:42:26:8B:01 arp=enabled
interface-type=Atheros AR5413 mode=bridge ssid="Bridgetooffice"
frequency=5620 band=5ghz scan-list=default antenna-mode=ant-a
compression=no
< -------------------- RB433 with Bridge and AP ----------------------->
WLAN2x is Bridge to RB600 WLAN2
WLAN3x Disabled
[admin@MikroTik] > ip add pr
192.168.0.34/24 192.168.0.0 192.168.0.255 ether1
0 name="wlan1" mtu=1500 mac-address=00:0C:42:26:BE:C4 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid="CalasparraAP"
compression=no
1 name="wlan2" mtu=1500 mac-address=00:0C:42:26:BE:E4 arp=enabled
interface-type=Atheros AR5413 mode=bridge ssid="CeheginBridge"
frequency=5180 band=5ghz scan-list=default antenna-mode=ant-a
compression=no
<--------------------------- network map ------------------------------------->
