Hello.
I had one RB3011 on a branch office, the router was working fine but due to an increase of the users i decided to change it with a Cloud Core.
I configured the Cloud Core identically as the 3011, but even with the same configuration i am having troubles. with my Unify Controller.
Everything was working fine with the 3011, but with the Cloud Core I have some issues:
The acces to the Unify Controller is only able from the localhost, i cant acces trough the web page from remote computer
Once inside the Unify Controller, all the acces point shows as offline.
I do have ping to the access points.
Cloud Core is configured with vlans, but the APs and Controller are in the same vlan.
The Cloud Core is CCR-1016 and runs 7.8 operating systemas as well as 3011
I also have a 3011 and I am in the process the setup to a new MikroTik Cloud Core Router CCR1009-7G-1C-1S+.
I hope this turns out to be a fairly simple process. Does anyone know if there is anything I need to do before attempting to load my current config into the CCR?
Hello.
Can you post your config using.
export hide-sensitive
