Probably i did not make myself clear
I have successfully set up snat and dnat. But, the problem occures only when I try to access web server’s public IP from local network.
Following is simplified configuration. Router, of course, has much more sofisticated rules. But, as the same thing is happening on brand new 2.9.19, with a lot simplier set-up, which I installed at office. We cannot access mailserver by Public IP from Local network: connection gets refused, because Mikrotik router thinks, that we are requesting routers’ 25th port, not the one address and port, which dnats to mailserver on Local network. So, after that I decided to write this post
So, back to configuration. Suppose, router has two Public IP adreses and one Local:
> /ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 10.0.0.1/24 10.0.0.0 10.0.0.255 Local
1 x.x.x.66/28 x.x.x.64 x.x.x.79 Public
2 x.x.x.69/28 x.x.x.64 x.x.x.79 Public
x.x.x.66 is used to access router. x.x.x.69 is our webserver.
Source NAT and destination NAT rules are like this:
> /ip firewall src-nat print
0 src-address=10.0.0.12/32 out-interface=Public action=nat to-src-address=x.x.x.69
> /ip firewall dst-nat print
0 in-interface=Public dst-address=x.x.x.69/32:80 protocol=tcp action=nat to-dst-address=10.0.0.12
Routes are default (wasn’t sure, if this info is required for this issue):
> /ip route print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected, C - connect, S - static, r - rip, o - ospf, b - bgp
# DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r x.x.x.65 1 Public
1 DC x.x.x.64/28 r 0.0.0.0 0 Public
2 DC 10.0.0.0/24 r 0.0.0.0 0 Local
So, when I am on Local network and fire Lynx or telnet to x.x.x.66:80, in return I get back router’s web page. That’s perferctly normal, because this address has no translations.
Now, when I am on Public network and browse to x.x.x.69:80, I have web server’s (10.0.0.12) reply. That is exactly, what I was intended to do.
But now, let’s try to browse to x.x.x.69 from Local network (for instance, 10.0.0.12 or any other host). What do we get? Mikrotik router’s web page. Instead of what seemed to be the most normal answer - 10.0.0.12:80.
