Problems with Dell PowerEdge
Hello, i’m having problems to install mikrotik on dell poweredge r430 … When i try install the follow error appear No harddrives found!
I need to know with router os support :
Raid controllers
PERC H330
PERC H730
Sorry for my bad english..
I doubt RouterOS contains HW RAID drivers.
A possible alternative: check if your server has a regular IDE or SATA port for DVD and plug a SSD there to install RouterOS on.
Dell has always been one of my top favorite computer manufacturers because of their wonderful services. I will suggest you to take help from the company directly itself. I am sure you will get your problem solved.
I installed esxi on a USB key. RouterOs is tiny, can it be installed on one of those?
I did the installation with pen drive , but the mikrotik dont recognized the drivers and the l2 mtu…
