Problems with DHCP
i try to set up DHCP server, but i receive the following message:
[admin@MikroTik] ip dhcp-server> print
ERROR: error - contact MikroTik support and send a supout file (2)
what can be a problem?
p.s. there is no files under “file”
system used: Pentium, 120MHz, 32 MB RAM
MT OS version: 2.8
supout.rif file has to be generated with the command /system sup-out
also, an upgrade to 2.8.12 is strongly suggested !
Quote from the manual:
Hardware requirements
  • CPU and motherboard - advanced 4th generation (core frequency 100MHz or more), 5th generation (Intel Pentium, Cyrix 6X86, AMD K5 or comparable) or newer uniprocessor Intel IA-32 (i386) compatible (multiple processors are not supported)
  • RAM - minimum 48 MB, maximum 1 GB; 64 MB or more recommended
  • Hard Drive/Flash - standard ATA interface controller and drive (SCSI and USB controllers and drives are not supported; RAID controllers that require additional drivers are not supported) with minimum of 64 MB space
It seems you should install more memory
