problems with Dude 2.0b2
-exported png file still dont exist, or I cannot find it?
-if logged in through web, when showing map picture, speed links dont exist…
  1. Tool-Export on the map works (PNG/PDF)
  2. Could you be more specific, which links you want to see or you don’t see?
  1. under local map - settings - export - png
    I cannot find where files are saved…
2)if you log to the dude through web, if you want to see map graphicly, you will see only links and routers, but not speeds like you can see it through client for windows…
for some reason, now, showing map through web is working :slight_smile:
