I have a problem with the new version of Dude v.3 who also happened in the 3rc03 version, but nevertheless in the beta version 3.08 is working properly.
The problem is to update the Mikrotik equipments from the dude server. with both versions (v3 and v3.0rc3), entering all the parameters introduced in the beta version 3.08 it is impossible to ‘upgrade’ or ‘force upgrade’.
The configuration used in the beta version 3.08 and in the v3 and v3.0rc3 is the same, but it only works properly with the v3.08 beta version.
I just agree that on The Dude version 3.0 is not possible to upgrade any mikrotik with 2.9.x version to newer version. In “upgrade” poup-up is not showed any possible version to upgrade. All possible packages are installed and im normaly possible to upgrade any 3.x version to an newer.
I do think that it is an bug in packages and theyr architectures since they are diferently named for 2.9.x versions and for 3.x ones.
I really dont understand what do you want to say. Did Mikrotik support say you that it will be solved in the next “The Dude” version? Also how did you contacted Mikrotik support?
Nice. Thank you for quick answer. Just one more quetion - Which is the best way to report bugs (for dude/mirkotik)? Im opensource deveolper and we usually use an bug tracker or mailing list for that purpose.
