Problems with generating LAG between CRS317 and Cisco SG350
Hello, my name is Marcos and I am new to the forum, greetings to all.
I need to check if anyone had trouble putting together a LAG between a CRS317 and a cisco SG350 switch. In the Cisco the LAG is configured in - mode: active with LACP, and in the CRS317 it does not matter how you set it - active, passive or static - the LAG is not generated. Any suggestions ??
Greetings
