PRoblems with graphical in new rbs
hello,
I have old rb532a v2.9.50 work fine… and new rb 433 v3.2 and rb600 v3.2. work fine.. except for this..
In old rb532, I configured the interfaces graphics, and same condition in new rbs.. but in rb532 when power is off and power is on again.. this rbs dont erase tha data of graphical… only erase this data when I make a reboot by software.
The new rbs, if the power is down.. and power is on… erase the data of graphical.
Additional, in rb532.. if a client wireless put your CPE off, the rb is all time make the graphics historical..
in New rbs v3.2 if the client put the cpe in off, the rbs no make nothing.. and.. some times erase the historical graphs.
Where is the solution for, rb433 and rb600 maintain this graphs in memory is the power is off.. and graphs all intrefaces without the is necessary the cpe client is on..??
In all rb.. I select store on disk.. But this only ork in rb532 v2.9.50
Thank you.
make sure you have marked “store on disk” in your “Graphing” rules.
I’ve got the same problem. After software reboot the previous graphs disappear. RB450G, ver 3.30. Store on disk = yes. :frowning:
Same here on RB1000 and RB450G on v4.1, I’m sending you supout.
Thanks.
