Hello dear Mikrotik community,
I have a problem with my hybrid port configuration on my CRS328-24P-4S+. I created the configuration using the article https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#VLAN_Example_.232_.28Trunk_and_Hybrid_Ports.29 .
I have a TP-Link EAP hanging on ports ether15 - ether17 which should treat VLAN 20 as untagged VLAN, and VLANs 10,40,50 as tagged VLANs, however only the tagged ports which were already configured from the old setup on the EAPs work, untagged I can’t get to the fixed assigned IP and I don’t know why.
Here is my setup:
add name=bridge1 vlan-filtering=no
add bridge=bridge1 interface=ether15 pvid=20
add bridge=bridge1 interface=ether16 pvid=20
add bridge=bridge1 interface=ether17 pvid=20
/interface bridge vlan
add bridge=bridge1 tagged=ether15,ether16,ether17,bridge1 vlan-ids=10
add bridge=bridge1 tagged=bridge1 untagged=ether15,ether16,ether17 vlan-ids=20
add bridge=bridge1 tagged=ether15,ether16,ether17 vlan-ids=40
add bridge=bridge1 tagged=ether15,ether16,ether17 vlan-ids=50
/interface vlan
add interface=bridge1 vlan-id=10 name=MGMT10
add interface=bridge1 vlan-id=20 name=MGMT20
add address=10.0.10.5/24 interface=MGMT10
add address=10.0.20.5/24 interface=MGMT20
/interface bridge set bridge1 vlan-filtering=yes
Does anyone have any idea why this is not working the way I want it to?
Thanks for your help in advance.
tdw
December 13, 2020, 11:42pm
2
That is not the actual configuration on the device, post the output of /export hide-sensitive
I know, however I did not want to specify the other ports as they work as pure tagged and untagged VLANs respectively. Here is the result of the command
, I have removed the serial number.
[admin@MikroTik] > /export hide-sensitive
# jan/06/1970 14:47:09 by RouterOS 6.47.8
# software id = QHVL-FCWQ
# model = CRS328-24P-4S+
# serial number =
add ingress-filtering=yes name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=MGMT10 vlan-id=10
add interface=bridge1 name=MGMT20 vlan-id=20
/interface bonding
add mode=802.3ad name=LACP1 slaves=ether11,ether12,ether13,ether14 \
transmit-hash-policy=layer-2-and-3
add bridge=bridge1 interface=ether1 pvid=10
add bridge=bridge1 interface=ether2 pvid=20
add bridge=bridge1 interface=ether3 pvid=30
add bridge=bridge1 interface=ether4 pvid=50
add bridge=bridge1 interface=ether5 pvid=20
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7 pvid=10
add bridge=bridge1 interface=ether8 pvid=10
add bridge=bridge1 interface=ether9 pvid=10
add bridge=bridge1 interface=ether10 pvid=10
add bridge=bridge1 interface=LACP1
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23 pvid=60
add bridge=bridge1 interface=ether24 pvid=60
add bridge=bridge1 interface=sfp-sfpplus1 pvid=70
add bridge=bridge1 interface=sfp-sfpplus2 pvid=70
add bridge=bridge1 tagged=ether6,ether15,ether16,ether17,LACP1,bridge1 \
untagged=ether1,ether7,ether8,ether9,ether10 vlan-ids=10
add bridge=bridge1 tagged=ether6,LACP1,bridge1 untagged=\
ether2,ether5,ether15,ether17 vlan-ids=20
add bridge=bridge1 tagged=ether6,LACP1 untagged=ether3 vlan-ids=30
add bridge=bridge1 tagged=ether6,ether15,ether16,ether17,LACP1 untagged=ether4 \
vlan-ids=40
add bridge=bridge1 tagged=ether6,ether15,ether16,ether17,LACP1 vlan-ids=50
add bridge=bridge1 tagged=ether6,LACP1 untagged=ether23,ether24 vlan-ids=60
add bridge=bridge1 untagged=sfp-sfpplus1,sfp-sfpplus2 vlan-ids=70
add address=10.0.10.5/24 interface=MGMT10 network=10.0.10.0
add address=10.0.20.5/24 interface=MGMT20 network=10.0.20.0
/system routerboard settings
set boot-os=router-os
anav
December 15, 2020, 1:02pm
4
That is nowhere near the config.
ex. You didnt define vlans 50,60,70.
One cannot have a single AP hanging off three ports, so I will assume you meant an EAP245 per port.
Needing tagged and untagged ports.
Did you try the following
oops I had this reversed LOL edit in progress As PER kenakapheus below!!
(if you ever want vlan 20 to be tagged and the other three vlans to be untagged I have the config ready LOL.)
ether2,ether5,ether15,ether16 ,ether17 vlan-ids=20
You missed ether16 as untagged on vlan 20
Yes you are right, I have 3 EAP225, however only 2 are functional, the third is in repair.
I used the following instructions for setting up the Switch:
/interface bonding
add slaves=ether11,ether12,ether13,ether14 mode=802.3ad lacp-rate=30secs link-monitoring=mii transmit-hash-policy=layer-2-and-3 name=LACP1
add bridge=bridge1 tagged=ether6,ether15,ether16,ether17,LACP1,bridge1 untagged=ether1,ether7,ether8,ether9,ether10 vlan-ids=10
add bridge=bridge1 tagged=ether6,LACP1,bridge1 untagged=ether2,ether5,ether15,ether17 vlan-ids=20
add bridge=bridge1 tagged=ether6,ether15,ether16,ether17,LACP1 untagged=ether4 vlan-ids=40
/interface vlan
ether16 is not importend at the moment, the AP for this port ist broken and in repair
tdw
December 15, 2020, 4:35pm
8
You can actually leave out the untagged= settings under /interface bridge vlan, they will be dynamically added based on the pvid= settings under /interface bridge port, so it would simplify to
add bridge=bridge1 tagged=ether6,ether15,ether16,ether17,LACP1,bridge1 vlan-ids=10
add bridge=bridge1 tagged=ether6,LACP1,bridge1 vlan-ids=20
add bridge=bridge1 tagged=ether6,LACP1 vlan-ids=30
add bridge=bridge1 tagged=ether6,ether15,ether16,ether17,LACP1 vlan-ids=40
add bridge=bridge1 tagged=ether6,LACP1 vlan-ids=60
add bridge=bridge1 vlan-ids=70
So ether15/16/17 transport VLAN 20 untagged and VLANs 10,40,50 tagged, and you should be able to access anything on the 10.0.10.0/24 or 10.0.20.0/24 subnets from the Mikrotik. When you say “untagged I can’t get to the fixed assigned IP” where are you accessing from?
Unfortunately this way doesn’t work either. Do you maybe have another idea.
I deleted the port ether17 from the bridge and added it with the commands
and tagged it manually via the winbox application, attached you can find the new config I fetched via /export hide-sensitive.
/interface vlan
/interface bonding
add mode=802.3ad name=LACP1 slaves=ether11,ether12,ether13,ether14 transmit-hash-policy=layer-2-and-3
/ip hotspot profile
add bridge=bridge1 tagged=ether6,LACP1,bridge1 untagged=ether2,ether15,ether22,ether5 vlan-ids=20
