Problems with ID routers in OSPF Instance
i’m changing to OSPF router ID instance in my routers.
I see that some old router ID still presents in the TAB “AS Border Routers”. And the Cost for these instance are very high.
Is this normal? I tried to reloaded some of these routers but the problem persist.
Someone can help me.
Thanks.
Please post the output of the following commands
/routing ospf export
/routing ospf neighbor print detail
/routing ospf as-border-router print detail
Hi, i post the output you asked:
routing ospf export
oct/21/2020 14:19:54 by RouterOS 6.47.2
software id = GGNF-8DCL
model = RB750Gr3
serial number = 8AFF0BBAA99C
/routing ospf area
add area-id=0.0.0.57 name=area8
/routing ospf instance
set [ find default=yes ] redistribute-connected=as-type-1 router-id=10.63.243.5
/routing ospf interface
add authentication=md5 authentication-key=***** interface=
ether1 network-type=point-to-point
add interface=bridge_mngt network-type=broadcast passive=yes
add interface=ether2 network-type=broadcast passive=yes
add interface=ether3 network-type=broadcast passive=yes
/routing ospf network
add area=area8 network=10.63.0.216/30
add area=area8 network=10.59.10.0/24
add area=area8 network=10.59.11.0/24
add area=area8 network=10.63.243.5/32
[ADM@R] > routing ospf neighbor print detail
0 instance=default router-id=10.63.243.4 address=10.63.0.217
interface=ether1 priority=1 dr-address=0.0.0.0
backup-dr-address=0.0.0.0 state="Full" state-changes=5 ls-retransmits=0
ls-requests=0 db-summaries=0 adjacency=5d21h8m29s
[ADM@R] > routing ospf as-border-router print detail
0 instance=default routerid=0.0.0.11 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4830
1 instance=default routerid=0.0.0.13 state=inter-area gateway=10.63.0.217 interface=ether1 cost=6010
2 instance=default routerid=0.0.0.16 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5810
3 instance=default routerid=0.0.0.26 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5810
4 instance=default routerid=0.0.0.40 state=inter-area gateway=10.63.0.217 interface=ether1 cost=11380
5 instance=default routerid=0.0.0.44 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5870
6 instance=default routerid=0.0.0.47 state=inter-area gateway=10.63.0.217 interface=ether1 cost=11360
7 instance=default routerid=0.0.0.51 state=inter-area gateway=10.63.0.217 interface=ether1 cost=11300
8 instance=default routerid=0.0.0.57 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4840
9 instance=default routerid=0.0.0.60 state=inter-area gateway=10.63.0.217 interface=ether1 cost=9600
10 instance=default routerid=0.0.0.63 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5780
11 instance=default routerid=0.0.0.71 state=inter-area gateway=10.63.0.217 interface=ether1 cost=39260
12 instance=default routerid=0.0.0.74 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5890
13 instance=default routerid=0.0.0.80 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5760
14 instance=default routerid=0.0.0.81 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5750
15 instance=default routerid=0.0.0.88 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4940
16 instance=default routerid=0.0.0.89 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4580
17 instance=default routerid=0.0.0.90 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5040
18 instance=default routerid=0.0.0.94 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4875
19 instance=default routerid=0.0.0.99 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4800
20 instance=default routerid=0.0.0.102 state=inter-area gateway=10.63.0.217 interface=ether1 cost=2150
21 instance=default routerid=0.0.0.110 state=inter-area gateway=10.63.0.217 interface=ether1 cost=1760
22 instance=default routerid=0.0.0.113 state=inter-area gateway=10.63.0.217 interface=ether1 cost=120
23 instance=default routerid=0.0.0.116 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4070
24 instance=default routerid=0.0.0.117 state=inter-area gateway=10.63.0.217 interface=ether1 cost=27640
25 instance=default routerid=0.0.0.122 state=inter-area gateway=10.63.0.217 interface=ether1 cost=237730
26 instance=default routerid=0.0.0.127 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5890
27 instance=default routerid=0.0.0.128 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5880
28 instance=default routerid=0.0.0.141 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5920
29 instance=default routerid=0.0.0.143 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4420
30 instance=default routerid=0.0.0.152 state=inter-area gateway=10.63.0.217 interface=ether1 cost=6000
31 instance=default routerid=0.0.0.155 state=inter-area gateway=10.63.0.217 interface=ether1 cost=2950
32 instance=default routerid=0.0.0.162 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5890
33 instance=default routerid=0.0.0.170 state=inter-area gateway=10.63.0.217 interface=ether1 cost=74120
34 instance=default routerid=0.0.0.176 state=inter-area gateway=10.63.0.217 interface=ether1 cost=11850
35 instance=default routerid=0.0.0.201 state=inter-area gateway=10.63.0.217 interface=ether1 cost=5050
36 instance=default routerid=10.56.0.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=100
37 instance=default routerid=10.63.240.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=80
38 instance=default routerid=10.63.240.2 state=inter-area gateway=10.63.0.217 interface=ether1 cost=90
39 instance=default routerid=10.63.240.4 state=inter-area gateway=10.63.0.217 interface=ether1 cost=70
40 instance=default routerid=10.63.240.5 state=inter-area gateway=10.63.0.217 interface=ether1 cost=80
41 instance=default routerid=10.63.240.8 state=inter-area gateway=10.63.0.217 interface=ether1 cost=80
42 instance=default routerid=10.63.240.10 state=inter-area gateway=10.63.0.217 interface=ether1 cost=60
43 instance=default routerid=10.63.240.14 state=inter-area gateway=10.63.0.217 interface=ether1 cost=80
44 instance=default routerid=10.63.240.16 state=inter-area gateway=10.63.0.217 interface=ether1 cost=80
45 instance=default routerid=10.63.240.17 state=inter-area gateway=10.63.0.217 interface=ether1 cost=90
46 instance=default routerid=10.63.240.18 state=inter-area gateway=10.63.0.217 interface=ether1 cost=100
47 instance=default routerid=10.63.240.24 state=inter-area gateway=10.63.0.217 interface=ether1 cost=60
48 instance=default routerid=10.63.240.25 state=inter-area gateway=10.63.0.217 interface=ether1 cost=70
49 instance=default routerid=10.63.240.34 state=inter-area gateway=10.63.0.217 interface=ether1 cost=190
50 instance=default routerid=10.63.240.35 state=inter-area gateway=10.63.0.217 interface=ether1 cost=200
51 instance=default routerid=10.63.240.38 state=inter-area gateway=10.63.0.217 interface=ether1 cost=2020
52 instance=default routerid=10.63.240.40 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
53 instance=default routerid=10.63.240.41 state=inter-area gateway=10.63.0.217 interface=ether1 cost=120
54 instance=default routerid=10.63.241.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=130
55 instance=default routerid=10.63.241.4 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
56 instance=default routerid=10.63.241.5 state=inter-area gateway=10.63.0.217 interface=ether1 cost=90
57 instance=default routerid=10.63.241.7 state=inter-area gateway=10.63.0.217 interface=ether1 cost=100
58 instance=default routerid=10.63.241.13 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
59 instance=default routerid=10.63.241.14 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
60 instance=default routerid=10.63.241.16 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
61 instance=default routerid=10.63.241.18 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
62 instance=default routerid=10.63.241.19 state=inter-area gateway=10.63.0.217 interface=ether1 cost=100
63 instance=default routerid=10.63.241.20 state=inter-area gateway=10.63.0.217 interface=ether1 cost=2240
64 instance=default routerid=10.63.241.25 state=inter-area gateway=10.63.0.217 interface=ether1 cost=120
65 instance=default routerid=10.63.241.28 state=inter-area gateway=10.63.0.217 interface=ether1 cost=2230
66 instance=default routerid=10.63.241.29 state=inter-area gateway=10.63.0.217 interface=ether1 cost=140
67 instance=default routerid=10.63.241.36 state=inter-area gateway=10.63.0.217 interface=ether1 cost=100
68 instance=default routerid=10.63.241.38 state=inter-area gateway=10.63.0.217 interface=ether1 cost=150
69 instance=default routerid=10.63.241.39 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
70 instance=default routerid=10.63.242.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=180
71 instance=default routerid=10.63.242.3 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
72 instance=default routerid=10.63.242.4 state=inter-area gateway=10.63.0.217 interface=ether1 cost=180
73 instance=default routerid=10.63.242.7 state=inter-area gateway=10.63.0.217 interface=ether1 cost=150
74 instance=default routerid=10.63.242.13 state=inter-area gateway=10.63.0.217 interface=ether1 cost=140
75 instance=default routerid=10.63.242.14 state=inter-area gateway=10.63.0.217 interface=ether1 cost=150
76 instance=default routerid=10.63.242.17 state=inter-area gateway=10.63.0.217 interface=ether1 cost=150
77 instance=default routerid=10.63.242.18 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
78 instance=default routerid=10.63.242.22 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
79 instance=default routerid=10.63.242.23 state=inter-area gateway=10.63.0.217 interface=ether1 cost=170
80 instance=default routerid=10.63.242.25 state=inter-area gateway=10.63.0.217 interface=ether1 cost=190
81 instance=default routerid=10.63.243.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=50
82 instance=default routerid=10.63.243.2 state=inter-area gateway=10.63.0.217 interface=ether1 cost=50
83 instance=default routerid=10.63.243.3 state=intra-area gateway=10.63.0.217 interface=ether1 cost=40
84 instance=default routerid=10.63.243.4 state=intra-area gateway=10.63.0.217 interface=ether1 cost=10
85 instance=default routerid=10.63.243.7 state=inter-area gateway=10.63.0.217 interface=ether1 cost=1810
86 instance=default routerid=10.63.243.8 state=inter-area gateway=10.63.0.217 interface=ether1 cost=90
87 instance=default routerid=10.63.243.9 state=inter-area gateway=10.63.0.217 interface=ether1 cost=100
88 instance=default routerid=10.63.243.12 state=inter-area gateway=10.63.0.217 interface=ether1 cost=3680
89 instance=default routerid=10.63.243.13 state=intra-area gateway=10.63.0.217 interface=ether1 cost=100
90 instance=default routerid=10.63.243.16 state=intra-area gateway=10.63.0.217 interface=ether1 cost=120
91 instance=default routerid=10.63.243.18 state=inter-area gateway=10.63.0.217 interface=ether1 cost=3010
92 instance=default routerid=10.63.243.19 state=intra-area gateway=10.63.0.217 interface=ether1 cost=90
93 instance=default routerid=10.63.243.23 state=inter-area gateway=10.63.0.217 interface=ether1 cost=40
94 instance=default routerid=10.63.243.24 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
95 instance=default routerid=10.63.243.26 state=inter-area gateway=10.63.0.217 interface=ether1 cost=2640
96 instance=default routerid=10.63.244.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=180
97 instance=default routerid=10.63.244.3 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
98 instance=default routerid=10.63.244.5 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
99 instance=default routerid=10.63.244.7 state=inter-area gateway=10.63.0.217 interface=ether1 cost=170
100 instance=default routerid=10.63.244.12 state=inter-area gateway=10.63.0.217 interface=ether1 cost=130
101 instance=default routerid=10.63.244.16 state=inter-area gateway=10.63.0.217 interface=ether1 cost=170
102 instance=default routerid=10.63.244.17 state=inter-area gateway=10.63.0.217 interface=ether1 cost=170
103 instance=default routerid=10.63.245.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=120
104 instance=default routerid=10.63.245.3 state=inter-area gateway=10.63.0.217 interface=ether1 cost=100
105 instance=default routerid=10.63.245.4 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
106 instance=default routerid=10.63.245.5 state=inter-area gateway=10.63.0.217 interface=ether1 cost=130
107 instance=default routerid=10.63.245.6 state=inter-area gateway=10.63.0.217 interface=ether1 cost=140
108 instance=default routerid=10.63.245.7 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4280
109 instance=default routerid=10.63.245.9 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
110 instance=default routerid=10.63.245.12 state=inter-area gateway=10.63.0.217 interface=ether1 cost=120
111 instance=default routerid=10.63.245.15 state=inter-area gateway=10.63.0.217 interface=ether1 cost=110
112 instance=default routerid=10.63.245.16 state=inter-area gateway=10.63.0.217 interface=ether1 cost=120
113 instance=default routerid=10.63.246.1 state=intra-area gateway=10.63.0.217 interface=ether1 cost=130
114 instance=default routerid=10.63.246.3 state=intra-area gateway=10.63.0.217 interface=ether1 cost=110
115 instance=default routerid=10.63.246.10 state=intra-area gateway=10.63.0.217 interface=ether1 cost=120
116 instance=default routerid=10.63.248.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=140
117 instance=default routerid=10.63.248.2 state=inter-area gateway=10.63.0.217 interface=ether1 cost=150
118 instance=default routerid=10.63.248.3 state=inter-area gateway=10.63.0.217 interface=ether1 cost=160
119 instance=default routerid=10.63.250.1 state=inter-area gateway=10.63.0.217 interface=ether1 cost=140
As you can see, there are some cost very high, and the routerid of that routers are non more active. For exemple, the first one:
"0 instance=default routerid=0.0.0.11 state=inter-area gateway=10.63.0.217 interface=ether1 cost=4830"
has the new router ID 10.63.244.7:
"99 instance=default routerid=10.63.244.7 state=inter-area gateway=10.63.0.217 interface=ether1 cost=170 "
Thank you for your help.
