Dear reader,
my goal is, to have my RB750Gr3 act as NAT server for my local network and send internet requests via an IKEv2 tunnel over my VPS running a Strongswan server.
In this way I want to get a public IP for the HEX and the option of forwarding various ports to devices in my local network.
My ISP doesn’t provide a public IP, so that is why.
I want to use IKEv2 instead of openvpn as not to throttle my connection too much.
Here is a graphic of my layout:
I setup the Hex as an IKEv2 client, but while I do get the connection to show under active peers, it won’t show any installed SAs.
The output of the Strongswan server is:
Apr 1 14:12:15 v2202003116426111615 charon: 07[ENC] parsed IKE_SA_INIT request 0 [ N(NATD_D_IP) N(NATD_S_IP) No KE SA ]
Apr 1 14:12:15 v2202003116426111615 charon: 07[IKE] 109.40.241.244 is initiating an IKE_SA
Apr 1 14:12:15 v2202003116426111615 charon: 07[IKE] remote host is behind NAT
Apr 1 14:12:15 v2202003116426111615 charon: 07[ENC] generating IKE_SA_INIT response 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(MULT_AUTH) ]
Apr 1 14:12:15 v2202003116426111615 charon: 08[ENC] parsed IKE_AUTH request 1 [ IDi CERT N(INIT_CONTACT) SA TSi TSr CPRQ(ADDR MASK SUBNET DNS) ]
Apr 1 14:12:15 v2202003116426111615 charon: 08[IKE] received end entity cert "CN=VPN root CA"
Apr 1 14:12:15 v2202003116426111615 charon: 08[IKE] EAP-Identity request configured, but not supported
Apr 1 14:12:15 v2202003116426111615 charon: 08[IKE] initiating EAP_MSCHAPV2 method (id 0x91)
Apr 1 14:12:15 v2202003116426111615 charon: 08[IKE] authentication of 'xx.xx.xx.xx' (myself) with RSA signature successful
Apr 1 14:12:15 v2202003116426111615 charon: 08[IKE] sending end entity cert "CN=xx.xx.xx.xx"
Apr 1 14:12:15 v2202003116426111615 charon: 08[ENC] generating IKE_AUTH response 1 [ IDr CERT AUTH EAP/REQ/MSCHAPV2 ]
Apr 1 14:12:16 v2202003116426111615 charon: 09[ENC] parsed IKE_AUTH request 2 [ EAP/RES/MSCHAPV2 ]
Apr 1 14:12:16 v2202003116426111615 charon: 09[IKE] EAP-MS-CHAPv2 username: 'user'
Apr 1 14:12:16 v2202003116426111615 charon: 09[ENC] generating IKE_AUTH response 2 [ EAP/REQ/MSCHAPV2 ]
Apr 1 14:12:16 v2202003116426111615 charon: 10[ENC] parsed IKE_AUTH request 3 [ EAP/RES/MSCHAPV2 ]
Apr 1 14:12:16 v2202003116426111615 charon: 10[IKE] EAP method EAP_MSCHAPV2 succeeded, MSK established
Apr 1 14:12:16 v2202003116426111615 charon: 10[ENC] generating IKE_AUTH response 3 [ EAP/SUCC ]
Apr 1 14:12:16 v2202003116426111615 charon: 11[ENC] parsed IKE_AUTH request 4 [ AUTH ]
Apr 1 14:12:16 v2202003116426111615 charon: 11[IKE] authentication of 'CN=VPN root CA' with EAP successful
Apr 1 14:12:16 v2202003116426111615 charon: 11[IKE] authentication of 'xx.xx.xx.xx' (myself) with EAP
Apr 1 14:12:16 v2202003116426111615 charon: 11[IKE] IKE_SA ikev2-vpn[1] established between xx.xx.xx.xx[xx.xx.xx.xx]...109.40.241.244[CN=VPN root CA]
Apr 1 14:12:16 v2202003116426111615 charon: 11[IKE] peer requested virtual IP %any
Apr 1 14:12:16 v2202003116426111615 charon: 11[IKE] assigning virtual IP 10.10.10.10 to peer 'user'
Apr 1 14:12:16 v2202003116426111615 charon: 11[IKE] CHILD_SA ikev2-vpn{1} established with SPIs c022c28d_i 0997b0ed_o and TS 0.0.0.0/0 === 10.10.10.10/32
Apr 1 14:12:16 v2202003116426111615 charon: 11[ENC] generating IKE_AUTH response 4 [ AUTH CPRP(ADDR DNS DNS) SA TSi TSr ]
Apr 1 14:12:16 v2202003116426111615 charon: 13[ENC] parsed INFORMATIONAL request 5 [ N(TS_UNACCEPT) D ]
Apr 1 14:12:16 v2202003116426111615 charon: 13[IKE] received DELETE for ESP CHILD_SA with SPI 0997b0ed
Apr 1 14:12:16 v2202003116426111615 charon: 13[IKE] closing CHILD_SA ikev2-vpn{1} with SPIs c022c28d_i (0 bytes) 0997b0ed_o (0 bytes) and TS 0.0.0.0/0 === 10.10.10.10/32
Apr 1 14:12:16 v2202003116426111615 charon: 13[IKE] sending DELETE for ESP CHILD_SA with SPI c022c28d
Apr 1 14:12:16 v2202003116426111615 charon: 13[IKE] CHILD_SA closed
Apr 1 14:12:16 v2202003116426111615 charon: 13[ENC] generating INFORMATIONAL response 5 [ D ]
The router is configured as follows:
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec mode-config
add name=netcupVPN responder=no src-address-list=VPN_LAN
/ip ipsec policy group
add name=netcupVPN
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-128 name=netcupVPN
/ip ipsec peer
add address=xx.xx.xx.xx/32 exchange-mode=ike2 name=netcupVPN profile=netcupVPN
/ip ipsec proposal
add enc-algorithms=aes-128-cbc,3des name=netcupVPN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=192.168.88.0/24 list=VPN_LAN
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" \
dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=\
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
established,related disabled=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=srcnat dst-address=xx.xx.xx.xx src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
out-interface-list=WAN
/ip ipsec identity
add auth-method=eap certificate=ca-cert.pem_0 eap-methods=eap-mschapv2 mode-config=netcupVPN \
password=yolo peer=netcupVPN policy-template-group=netcupVPN username=vr1l
/ip ipsec policy
add dst-address=0.0.0.0/0 group=netcupVPN proposal=netcupVPN src-address=0.0.0.0/0 template=yes
And this is my ipsec.conf:
config setup
charondebug="ike 1, knl 1, cfg 0"
uniqueids=no
conn ikev2-vpn
auto=add
compress=no
type=tunnel
keyexchange=ikev2
ike=aes256-sha1-modp1024,aes128-sha1-modp1024,3des-sha1-modp1024!
esp=aes256-sha256,aes256-sha1,3des-sha1!
fragmentation=yes
forceencaps=yes
dpdaction=clear
dpddelay=300s
rekey=no
left=%any
leftid=xx.xx.xx.xx
leftcert=server-cert.pem
leftsendcert=always
leftsubnet=0.0.0.0/0
right=%any
rightid=%any
rightauth=eap-mschapv2
rightsourceip=10.10.10.10
rightdns=8.8.8.8,8.8.4.4
rightsendcert=never
eap_identity=%identity
So, if you have any idea, what I am doing wrong or even a hint to any resources I should study next I would be really grateful.
