Anyone having issues with speed over L2TP please post as many details as you can. We removed the old topic because it went too far into offtopic.
NO issues here…
Hi Normis,
We found the solution with bad trhuput in the VPN conections. It was in the BGP router side.
When we removed the MT router and put in a JP2320 then the problem was gone.
So it must be related to the BGP . we have 30 Psc of MT routers that are working well now. and the Speed is up again in the VPN tunnels
, But my tech was kickt out from this forum becours he used bad language i think, he was suposed to type in the solution that we found…
but he was not able to to that anymore…
//Rickard
I don’t think anyone has been kicked off. If you are not civil and technical, then your message (or topic) will be deleted and you will only be kicked off if you continue in the same way. Any issues with administration should be emailed to support@mikrotik.com (not to the forum) – this is a rule.
