Hi all!
I’m seeing some issues when attempting to use a Marvell 88E8056 based NIC on RouterOS 5.7. The particular link I’m having difficulty with requires to Speed/Duplex to be hard set to 100Mb/Full (with no autoneg).. This bit is fine..
However - it appears that the NIC is unable to negotiate correctly due to having flow-control autonegotation still enabled at the router end, and starts flapping.
It’s an easy resolve on Linux - ethtool [ethX] -A autoneg off tx off rx off - However I can’t see an option to control ethernet flow control on RouterOS.
Any ideas of a work-around.. Vyatta has a disable-flow-control option for each Ethernet interface and this sort of thing would be ideal!
Thanks,
Lee.
Open the Ethernet interface in winbox, head to the ethernet tab and untick “auto-negotiation” then click ok/apply.
Make sure you have the correct rate set (on this same tab) that you want it to connect at.
Thanks for the reply. It’s not the autoneg of the speed/duplex I’m having an issue with. This has been correctly set (e.g. /interface ethernet set speed=100Mbps full-duplex=yes auto-negotiation=no). It’s an issue that the NIC is still trying to autoneg ethernet flow-control which isn’t supported by the other end and drops the link on a continuous cycle.
Spoke to Mikrotik support and according to the response the ability to disable flow-control on ethernet interfaces will be added in an upcoming release. Until then I guess I’m going to have to shove a switch inline.
Appreciate your time to respond though.
Regards,
Lee.
