Hi All
Having a lot of issues trying to run SXT LTE units from hAP Lite AC units after moving the WAN port from 1 to 5. I don’t have a huge amount of experience with the configuration but have coped ok to date after deploying around 20 LTE units + routers using seperate power sources but really want to simplify the installations with one power source.
This is what i do to try and get the configuration to work:-
- go to interfaces and change WAN to Ether 5, add ether 1 back as a Lan.
- delete ether 5 from the bridge and add ether 1 back as a LAN
- change the DHCP client from Ether 1 to Ether 5.
- change the IP range so that its different to the SXT LTE
- apply a static route to the SXT LTE unit.
Once all this is done, everything works until i restart the Router then i lose internet and the WAN has shifted back to port 1 on the interfaces and the port 1 has become disabled on the bridge and i have to start again.
Can someone help me here as this is starting to drive me bananas as i can’t figure it out.
Many thanks.
Joe.
