I get error during netinstall discovery phase. I’m guessing it’s when the router makes the request. Error states: bind tftp general failed: Only one usage of each socket address (protocol/network address/port) is normally permitted - 10048. There’s no service using tftp ports, I run the program with admin privileges, firewall is down. I’ve tried a couple of routers and there’s the same error so I’m pretty sure the problem is on the windows machine - os is w10 x64. I also tried different ros versions, same error.
Any thoughts ?
