Problems with Outlook Service
I am trying to Send and Receive from an Outlook Client using Pop3 for receiving and SMTP for sending, but it can’t get through my firewalled Router PC. Please, I need some help, I am a beginer. Plz
you have to give more details about router firewall configuration.
ip firewall nat add chain=dstnat src-address=192.168.0.0/24 protocol=tcp dst-prot=80 action=redirect to-ports=8080
well, that’s just a rule to allow acces to some internal server from the outside and doesn’t help much with your question.
You should at least post your complete firewall config and ip setup…
Best regards,
Christian Meis
i think u block some port in your firewall try to use or update your rule like this:
/ ip firewall filter
add chain=input   dst-address=:135-139 protocol=tcp action=drop comment="" disabled=no
add chain=forward dst-address=:137-139 protocol=tcp action=drop comment="" disabled=no
add chain=forward dst-address=:137-139 protocol=udp action=drop comment="" disabled=no
i hope this slove your problem
Regards and good luck…
Does anyone knows where can I find a version of RouterPC that doesnt need the Key???
You don’t really want to ask for a c r a c k in an (more or less) official support forum from the manufacturer, do you?
If you do: GO AWAY or purchase a license - it’s worth every tenth of a cent you pay for it!
If you meant the 24-hour time-limited demo: Just install the software - it will run for 24 hours without a key…
Best regards,
Christian Meis
It is not that. I have heard that version 2.0 of RouterPC, doesnt need a key, is that, but I cant find it. If I cant find it, I will have to purchase a key. Does anyone knows the price???
Anybody, who is able to look at Mikrotik web pages.
all information about licenses and prices are here:
http://www.mikrotik.com/software.php
