Problems with PCC, ¿I can clear the bases of the PCC?
I am having a problem with load balancing, is a RB450G where Int I have a LAN and 4 WAN, Wan are ADSLs 6Mbps Down and 850Kbps Up To balance use PCC rules with IP destination, the problem is the following .
More often than is allowed access to some destinations, from what I saw is a problem on the basis that the algorithm PCC weapon. To resolve the problem restart the RB and everything is working normally … for some time
Ex accessed without problems a lot of locations but can not connect to www.google.com. This is just one example, as happens to any destination.
My question is: Is there a way to manage the base of the PCC? (Reset / monitoring). I can not find commands to manage the foundation of the PCC, are there?
Thank you.
