It seems after updating my router port forwarding seems to no longer work. I use the port mapping feature as I’m new to Router OS and it used to work for my game servers but now testing to see if i could get say port 7777 open, Each time i try adding the rule it doesn’t seem to allow it at all. Where as before when i was running a 7 days to die server and added the rules it worked perfectly.
I’m fairly new to Mikrotik routers but I’ll include information below - I’d really appreciate any help. Thank you in advance
Mikrotik RB5009 - Running Router OS latest Version
How do i export my firewall rules or info so you guys can look thru it ??
See here for a bit more info on what’s needed and how to get it:
http://forum.mikrotik.com/t/forum-rules/173010/1
# 2025-05-18 23:27:20 by RouterOS 7.18.2
# software id =
# model = RB5009UPr+S+
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] advertise="10M-baseT-half,10M-baseT-full,100M\
-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full" poe-out=off
set [ find default-name=ether2 ] poe-out=off
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=\
10 path-cost=10
set udp-timeout=10s
set discover-interface-list=none
/interface detect-internet
set detect-interface-list=WAN
/interface l2tp-server server
set use-ipsec=yes
add comment=defconf disabled=yes interface=ether1 list=WAN
/interface ovpn-server server
add mac-address= name=ovpn-server1
192.168.88.0
/ip arp
add address=192.168.88.254 comment= interface=bridge mac-address=\
add address=192.168.88.253 comment= interface=bridge mac-address=\
add address=192.168.88.252 comment="Theater PC" interface=bridge mac-address=\
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.254 client-id= mac-address=\
server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=\
1.1.1.1,8.8.8.8,1.1.1.2,1.0.0.1 gateway=192.168.88.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.88.254 list=
add address=192.168.88.253 list=
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
invalid
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=Abio dst-port=7777 in-interface-list=\
WAN protocol=udp to-addresses=192.168.88.254 to-ports=7777
add action=dst-nat chain=dstnat comment=abiot dst-port=7777 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.88.254 to-ports=\
7777
/ip ipsec profile
/ip service
set telnet disabled=yes port=
set ftp disabled=yes port=
set www port=
set ssh disabled=yes port=
set api disabled=yes
set winbox port=
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add disabled=yes name=vpn
/system clock
set time-zone-name=Australia
/system identity
set name=
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
I think i got it worked out for you
Ok and some information regarding my setup and what i would like
Normal user have Fibre coming into my house have a switch after the RB5009 distributing the internet to 3 pc’s
The RB5009 handles all of my internet - I would like a decent firewall and just a fairly standard setup i don’t have any need for VPN’s or anything else really yet.
I do host game servers for my friends and have a static IP as well
So my needs are fairly basic - Later on i would love to add some PoE camera’s and such but that can wait for a much later date
Thank you greatly for the help
anav
May 18, 2025, 7:09pm
5
Do you have a public IP.
Game servers attract hackers and is the reason why SANE people do not try to host them but use Steam etc…
However if you have public IP or an upstream ISP router where you can forward ports, suggest using wireguard for your friends to get to your router to game securely or even zerotier networking.
By the way it seems as you have VPN subnet, but your text said no need, so confusing to see it there.
Set this to none, known to cause weird issues…
set detect-interface-list=none
Since you mention future POE devices etc, it might be a good time to switch to vlans, and have the game server on its own subnet for starters.
