Problems with pppoe server rb3011
I am having problems with pppoe users connect get ip from navigation gateway and dns ai it works normal from nothing the user stops navigating with time there I go there change the user of it in rb and it navigates again someone already gone through it? It started happening around 4 days ago. Everything worked correctly. My vs is bugfix 6.37.4 already tried everything and does not solve this problem
Did you manage to resolve issue? I have simular problem.
In you post stand no idear what your Router does!
What happend when the error Start?
Your clients Loosing there pppoe Connection?
Can you Ping then?
Can they Ping your Router?
