Hi every one
I used radius and all points take authentication of a single box without any problems .
the problem, which happened to me there are as follows, I have a new network I have to merge three Internet lines where after merger i have an imbalance! The imbalance was due to the exit of the request of validated across the Line of Internet is not defined in main radius I mean, if if the request of validated went out of the pppoe1 be acceptance ..the request of the pppoe 2 or pppoe3 shows a letter there was no response from server I hope a solution to this problem… so that it would be the exit of the request of the authentication from pppoe1 only
How can i do that !!
you can use mangle to mark all packets with destination your radius server IP, and mark all with a routeing mark to use only pppoe1
thanks Ibersystems for rapid assistance
this is a mangle where is the point which will help in solving the problem .
/ip firewall mangle> p
0 chain=input action=mark-connection new-connection-mark=wan1 passthrough=yes
connection-state=new in-interface=pppoe-out1
1 I chain=input action=mark-connection new-connection-mark=wan2 passthrough=yes
connection-state=new in-interface=pppoe-out2
2 X chain=input action=mark-connection new-connection-mark=wan3 passthrough=yes
connection-state=new in-interface=pppoe-out3
3 chain=output action=mark-routing new-routing-mark=wan_1 passthrough=no
4 chain=output action=mark-routing new-routing-mark=wan_2 passthrough=no
5 X chain=output action=mark-routing new-routing-mark=wan_3 passthrough=no
6 chain=prerouting action=mark-connection new-connection-mark=wan1
passthrough=yes dst-address-type=!local in-interface=lan
per-connection-classifier=both-addresses-and-ports:3/0
7 chain=prerouting action=mark-connection new-connection-mark=wan2
per-connection-classifier=both-addresses-and-ports:3/1
8 X chain=prerouting action=mark-connection new-connection-mark=wan3
per-connection-classifier=both-addresses-and-ports:3/2
9 chain=prerouting action=mark-routing new-routing-mark=wan_1 passthrough=yes
in-interface=lan connection-mark=wan1
10 chain=prerouting action=mark-routing new-routing-mark=wan_2 passthrough=yes
in-interface=lan connection-mark=wan2
11 X chain=prerouting action=mark-routing new-routing-mark=wan_3 passthrough=yes
in-interface=lan connection-mark=wan3
I have to disabled pppoe2&pppoe3 until the end of the imbalance
hi,
I think first you have to mark connection, then mark packet and later mark routing of these packets.
dormador,
When you choose a topic, please choose something more descriptive. I just don’t like clicking into the topics having no idea what they’re about, when people say they need immediate solution.
update: topic has been changed
Thanx everybody but until know the problem stell here !!!
