Problems with RB750 after upgrading to v4.17
I’ve updated firmware on router to version 4.17 (from 4.11) to use new usermanager, now i can’t see profiler under ‘tools’ menu, and also router became unstable - it kicks me off winbox every 15-30 seconds.
Mostly it’s user for hotspot, we have transition to new user manager system (before there was simple users, managed from winbox), so both systems are active. CPU load jumps to 100%, and I can’t figure out where’s the problem because of profiler. I haven’t seen any ‘profiler’ package.
Here’s installed packages, may be I’ve forgot something?
 /system package print
Flags: X - disabled
 #   NAME                    VERSION                    SCHEDULED
 0   system                  4.17
 1   userman-test            4.17
 2 X user-manager            4.17
 3   hotspot                 4.17
 4   advanced-tools          4.17
 5   routerboard             4.17
 6   mpls                    4.17
 7   dhcp                    4.17
 8   routing                 4.17
 9   ppp                     4.17
10   security                4.17
Did you update the firmware as well? System → Routerboard → Update
now I see, that there’s also no ‘routerboard’ section in ‘system’ menu. what am i doing wrong?
Maybe v4 didn’t have that in the winbox.
Go to the terminal, and type this:
/system routerboard print
Paste the output here in this forum.
Then, type this:
/system routerboard upgrade
Choose y to confirm
Then, type this:
/system reboot
