I have asked for help to reduce the time it takes mikrotik on a wireless network, jumping from one access point to another, as too many packets are lost while roaming. I’ve tried various configurations, including CAPsMAN but not cosigo reduce the response time, the mikrotik clients lose too much time jumping from one AP to another.
I configured the same frequency, but still, many packets are lost.
What would be the recommended distance between APs and clients mikrotik settings? considering that all the equipment is mikrotik.
Thank you.
Sometimes it helps setting access lists to automatically “kick” clients with lower signals, to induce clients to connect to another AP.
Curious about the environment, using mobile mikrotik clients? you could also use connect to lists in the same fashion.
Gracias Pukita, eso ya lo he hecho, yando en el AP, como en el cliente, el problema es que curiosamente, pese a ser ambos equipos (AP y cliente) mikrotik, el tiempo de salto entre APs, es muy elevado y desde que enlaza hasta que tiene conectividad, pasa demasiado tiempo y se pierden muchos paquetes, en un ping continuo, unos 4 o 5. POr otro lado, es curiosos que con equipos estandar es decir de windows, el salto es ms rapido.
