Problems with ROS 7.4 in SXT 5HPnD
I try the 7.4 RouterOS in 2 P2P SXT 5HPnD devices.
They are not rock solid since I upgrade, the ping is getting big values and this is the proccessor and memory graph:
v
And this is the voltage graph:
I upgrade the devices at 15:40.
Is something wrong with the new RouterOS version in this devices?
Kind regards.
Can you back to ROS6?
Regards.
Yes, I downgrade to v6, now all is working well.
I will keep in v6, the device are just to make the p2p wireless link.
Regards.
Great!
Thanks for the info.
My recommendation is wait some versions more to see how stable will be.
I’m not tested yet ROS7 but I prefer wait some more time.
Regards.
Yes,
I will wait, but anyone has same problem? Just to know if it my problem or a global one?
Regards.
At least you can reconfigure your device with ROS7 to discard configuration problem/incompatibility. Remember do backup of your config.
Regards.
