Problems with RouterOs 3.12 in x86 environment!
does someone else has the same problems as we did after update to 3.12?
Two good running, complete different systems, in different environments 1000´s of kilometers from each other!
  1. RouterOs 3.11 on x86
  2. RouterOs 2.9.51 on x86
    did the same (nothing!) after updating to 3.12.
No possibility to reach the sytem either by ethernet (different ports!) or wireless.
Not even by a connectet terminal.
After reboot you see the welkom screen with login but you can´t enter anything.
I hope there will be an answer soon!!
There is also a Post in RouterOs forum (v3.12 crashing on x86) !!
I had better read before :frowning:
Try 3.13 :slight_smile:
I will, nxt month!!!, wenn there are no reply´s :slight_smile:
