I have a problem to redirect the mikrotik router to the port 3128 of the squid in another machine, I would like to know what do I have to change in my configuration:
Initially I have a proxy server in CentOS with squid and Firestarter (which makes NAT), the port that squid is listening is 3128
I have also a mikrotik router with NAT to pass the internet to my computer but in order to actually have internet in my computer i have to configure the proxy settings in my browser.
Then I tried to configure those settings inside of the router to make it transparent to the computers and not change the browser configurations in every computer. I tried this
where 192.168.2.1 is the gateway to reach the squid in my centos proxy
When I take out the proxy settings in my web browser I don´t have internet, I still need the browser configuration.
Can you give me any suggestion to make it transparent from the router and not from the squid itself?
You need to make your squid ready to interecpt packets sent from mk so u just need to edit your squid.conf file which should be in this dir on centos /usr/local/squid/etc and add the word “transparent” after “http_port 3128” then reconfigure squid or restart it, best regards
I actually did it, i added the “transparent” after the port and saved it then restarted the squid but still is not working.
Do you know what would be the problem?, thanks for your help
best regards
Maybe, if not misunderstood, IMHO, you have a conceptual error. You have to redirect to your Squid every request with dst-port 80, by means of a dst-nat, not a redirect, because de redirection direction must be the Squid expernal IP. If you did the “transparent” thing in squid.conf, try this rule in your Mikrotik:
