Problems with Vlans.
Hi, I’m trying to create a network with vlans, but the final device (PC with XP) can’t get IP from DHCP server.
I’m running x86 version of RouterOS (6.40.6) and a IOSvL2 Cisco switch.
Topology:
https://prnt.sc/iok75n
MK Config:
set [ find default-name=ether3 ] name=ether1-WAN
set [ find default-name=ether4 ] name=ether2
set [ find default-name=ether1 ] name=ether3
set [ find default-name=ether2 ] name=ether4
/interface vlan
add interface=ether2 name=vlan-10 vlan-id=10
add name=dhcp_pool0 ranges=192.168.40.2-192.168.40.254
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp_pool0 disabled=no interface=ether4 name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=vlan-10 name=dhcp2
add address=192.168.137.1/30 interface=ether1-WAN network=192.168.137.0
add address=192.168.40.1/24 interface=ether4 network=192.168.40.0
add address=192.168.10.1/24 interface=vlan-10 network=192.168.10.0
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.40.0/24 gateway=192.168.40.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface=ether1-WAN
add distance=1 gateway=192.168.137.2
Cisco running config:
Current configuration : 3620 bytes
! Last configuration change at 16:00:09 UTC Thu Mar 8 2018
version 15.2
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
spanning-tree extend system-id
vlan internal allocation policy ascending
interface GigabitEthernet0/0
 switchport trunk encapsulation dot1q
 switchport mode trunk
 media-type rj45
 negotiation auto
interface GigabitEthernet0/1
 switchport access vlan 10
 switchport mode access
 media-type rj45
 negotiation auto
interface GigabitEthernet0/2
 media-type rj45
 negotiation auto
interface GigabitEthernet0/3
 media-type rj45
 negotiation auto
interface GigabitEthernet1/0
 media-type rj45
 negotiation auto
interface GigabitEthernet1/1
 media-type rj45
 negotiation auto
interface GigabitEthernet1/2
 media-type rj45
 negotiation auto
interface GigabitEthernet1/3
 media-type rj45
 negotiation auto
interface GigabitEthernet2/0
 media-type rj45
 negotiation auto
interface GigabitEthernet2/1
 media-type rj45
 negotiation auto
interface GigabitEthernet2/2
 media-type rj45
 negotiation auto
interface GigabitEthernet2/3
 media-type rj45
 negotiation auto
interface GigabitEthernet3/0
 media-type rj45
 negotiation auto
interface GigabitEthernet3/1
 media-type rj45
 negotiation auto
interface GigabitEthernet3/2
 media-type rj45
 negotiation auto
interface GigabitEthernet3/3
 media-type rj45
 negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
 login
end
Regards.
Mikrotik config seems fine to me. Not too familiar with cisco, but don’t you need to set up what vlans are allowed on what ports (specifically 0/0 AND 0/1), other than just the switchport access vlan?
Probably, but if I add:
switchport trunk allowed vlan 1,10
still not working.
In the g0/1 I can’t find a command to specify allowed vlans when it’s in Access mode.
Regards.
This is supposed to be a Mikrotik forum, right?
On a Cisco port in access mode, there is only one VLAN, and you have stated that correctly:
On the trunk port,
switchport trunk allowed vlan 10
is also fine.
(you can have one of the VLANs on a trunk port tagless on the wire if you configure “switchport trunk native vlan X”, but that’s still not called an Access port - Cisco doesn’t call it a special name at all and all others call it a Hybrid port).
I’m afraid there may be an issue that you have to create the vlan 10 as such. What does “show vlan” say, is it in the list? If not,
conf t
vlan 10
exit
exit
Yes, the first that I did, was create the vlan 10.
Comands:
enable
configure terminal
vlan 10
name vlan-10
exit
Results:
https://prnt.sc/iolcx7
It’s very very strange.
Regards
Fine. What does “show mac address-table interface gigabitEthernet 0/0” and “show mac address-table interface gigabitEthernet 0/1” say?
Regards.
that’s the previous picture :slight_smile:
Can you instead copy the text, paste it here and mark it as code?
Sorry, there is the code:
Switch#show mac address-table int g0/0
          Mac Address Table
Vlan    Mac Address       Type        Ports
   1    0800.2774.26a3    DYNAMIC     Gi0/0
  10    0800.2774.26a3    DYNAMIC     Gi0/0
Total Mac Addresses for this criterion: 2
Switch#show mac address-table int g0/1
          Mac Address Table
  10    0800.27dd.d24f    DYNAMIC     Gi0/1
Total Mac Addresses for this criterion: 1
Switch#
Regards.
In your RB setup, you’re renaming the ports in a way which can cause confusion. According to the config, the trunk port to connect to cisco seems to be physical port ether4 (probably the right-most) while all the naming in the config suggests port ether2 (probably the second from left). I’d verify that and possibly remove renaming or do renaming to less confusing port names.
Unglaublich. I would expect to see the MAC address of the Mikrotik at gi 0/0, instead there is one from “PCS Systemtechnik GmbH”, another one from the same manufacturer is at gi 0/1.
Have you changed the MAC address on the Mikrotik to that 08:00:27:something? I don’t get how it could be learned in both VLAN 1 and VLAN 10 if the connected device would not have both VLANs activated (some VLAN tagless and the other VLAN 10 tagged).
Also, I’m a bit lost in your renaming of Ethernet ports and the picture. Your Mikrotik configuration says:
/interface vlan
whereas the picture shows that Gi0/0 of Cisco is connected to e0/1 of 'Tik. Are you sure you have not messed up the connection or configuration? Not that it would explain why the device actually connected to Gi0/0 has VLAN 10 tagged on it.
It should not be necessary in 6.40.6, but try to insert a bridge between vlan10 and ether2:
/interface bridge add name=X
/interface vlan set interface=X [find vlan-id=10]
/interface bridge port add bridge=X interface=ether2
There were issues with vlan interfaces being directly attached to physical interfaces in some 6.41 rcs, maybe 6.40.6 is affected.
Ok, I reconfigured again without renaming interfaces. I changed device. Post config and topology again:
Topology:
RouterOS Config:
/interface vlan
add name=dhcp_pool1 ranges=192.168.40.2-192.168.40.254
add name=dhcp_pool2 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay disabled=no interface=ether4 name=dhcp1
add address-pool=dhcp_pool2 authoritative=after-2sec-delay disabled=no interface=vlan-10 name=dhcp2
add address=192.168.137.1/30 interface=ether1 network=192.168.137.0
Cisco Show Run:
Current configuration : 3656 bytes
! Last configuration change at 19:37:38 UTC Thu Mar 8 2018
version 15.2
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
no ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
 login
end
Cisco Show Vlan:
VLAN Name                             Status    Ports
1    default                          active    Gi0/2, Gi0/3, Gi1/0, Gi1/1
                                                Gi1/2, Gi1/3, Gi2/0, Gi2/1
                                                Gi2/2, Gi2/3, Gi3/0, Gi3/1
                                                Gi3/2, Gi3/3
10   vlan-10                          active    Gi0/1
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Cisco Show Mac-Address G0/0 and G0/1:
          Mac Address Table
   1    0800.27bb.94c7    DYNAMIC     Gi0/0
  10    0800.27bb.94c7    DYNAMIC     Gi0/0
          Mac Address Table
Windows 7 Machine:
Windows XP Machine:
Regards.
OK. I’ve missed that you’re running an x86 version of RouterOS, that explains the unusual MAC addresses.
Now can you configure the IP address and mask manually on the WinXP machine to 192.168.10.2 and 255.255.255.0 and then try to ping the 192.168.10.1 from there? Maybe the VLAN part is fine but there is some issue with the DHCP server.
Also, can you create a Vlan10 interface in the Cisco, assign it 192.168.10.3/24 and try to ping it from both sides?
Is everything virtual or are there some physical components in your setup?
Its everything virtual.
I’m going to try it.
Regards.
Windows XP Machine configured:
Cisco configured:
 media-type rj45
 negotiation auto
interface Vlan10
 ip address 192.168.10.3 255.255.255.0
Ping results on Cisco:
Switch#ping 192.168.10.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 192.168.10.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Switch#ping 192.168.10.2
Sending 5, 100-byte ICMP Echos to 192.168.10.2, timeout is 2 seconds:
Switch#ping 192.168.10.3
Sending 5, 100-byte ICMP Echos to 192.168.10.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/3 ms
Ping results on Windows XP Machine:
C:\Documents and Settings\User>ping 192.168.10.1
Haciendo ping a 192.168.10.1 con 32 bytes de datos:
Tiempo de espera agotado para esta solicitud.
Estadísticas de ping para 192.168.10.1:
    Paquetes: enviados = 4, recibidos = 0, perdidos = 4
    (100% perdidos),
C:\Documents and Settings\User>ping 192.168.10.2
Haciendo ping a 192.168.10.2 con 32 bytes de datos:
Respuesta desde 192.168.10.2: bytes=32 tiempo<1m TTL=128
Estadísticas de ping para 192.168.10.2:
    Paquetes: enviados = 4, recibidos = 4, perdidos = 0
    (0% perdidos),
Tiempos aproximados de ida y vuelta en milisegundos:
    Mínimo = 0ms, Máximo = 0ms, Media = 0ms
C:\Documents and Settings\User>ping 192.168.10.3
Haciendo ping a 192.168.10.3 con 32 bytes de datos:
Respuesta desde 192.168.10.3: bytes=32 tiempo=6ms TTL=255
Respuesta desde 192.168.10.3: bytes=32 tiempo=41ms TTL=255
Respuesta desde 192.168.10.3: bytes=32 tiempo=8ms TTL=255
Estadísticas de ping para 192.168.10.3:
    (0% perdidos),
    Mínimo = 6ms, Máximo = 41ms, Media = 15ms
Regards.
OK, so the XP can ping the cisco but not vice versa, assuming it is because the XP’s firewall drops the incoming icmp echo requests. But there is no firewall on the Mikrotik.
I would continue by spawning another Cisco with similar configuration (VLAN 10 on a trunk port and an IP address on it) and connecting it to the existing CIsco instead of the Mikrotik, and another Mikrotik with VLAN 10 and an IP address on it connected to the existing Mikrotik, and pinging between each pair, to see whether it is the virtual environment or one of the virtual switches/routers what has a problem with tagged packets.
I tried with ROS 6.36 and ROS 6.40, and no changes.
With a Cisco 3745 still not working.
Regards.
Ok, you say something like this?
Regards.
Config first switch:
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
interface Vlan10
Note: G0/2 go to second switch.
Config second switch:
 media-type rj45
 negotiation auto
 interface Vlan10
 ip address 192.168.10.4 255.255.255.0
Note: G0/0 go to first switch.
Ping first switch:
Switch#ping 192.168.10.4
Sending 5, 100-byte ICMP Echos to 192.168.10.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/33/48 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/14/34 ms
Ping Second Switch:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/8/33 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/47/83 ms
Ping Windows XP Machine:
C:\Documents and Settings\User>ping 192.168.10.4
Haciendo ping a 192.168.10.4 con 32 bytes de datos:
Respuesta desde 192.168.10.4: bytes=32 tiempo=79ms TTL=255
Respuesta desde 192.168.10.4: bytes=32 tiempo=36ms TTL=255
Respuesta desde 192.168.10.4: bytes=32 tiempo=22ms TTL=255
Respuesta desde 192.168.10.4: bytes=32 tiempo=19ms TTL=255
Estadísticas de ping para 192.168.10.4:
    (0% perdidos),
    Mínimo = 19ms, Máximo = 79ms, Media = 39ms
Respuesta desde 192.168.10.3: bytes=32 tiempo=71ms TTL=255
Respuesta desde 192.168.10.3: bytes=32 tiempo=9ms TTL=255
Respuesta desde 192.168.10.3: bytes=32 tiempo=13ms TTL=255
    (0% perdidos),
    Mínimo = 9ms, Máximo = 71ms, Media = 25ms
    (0% perdidos),
    (100% perdidos),
Regards.
First Mikrotik:
Second Mikrotik:
Regards.
