Hello everybody
I’m having a problem with the proxy in version 3.11. I used to works with 3.0RC14 and the proxy works well. Now I update to version 3.11, because in pppoe, now, I have the option to insert automatic the client that connect to the address-list, intested of do it with a script. That works fantastic, but the problem now is the web-proxy, I can’t make it works!!
Well I will insert my configuration, if someone look something bad please tall me!!
/ip firewall nat> print
0 ;;; basic nat sobre red 10.10.0.0/16
chain=srcnat action=masquerade src-address=10.10.0.0/16 src-address-list=clientes_activos out-interface=DEDICADO
1 X ;;; toda la red 10.10.0.0/16 redirect proxy
chain=dstnat action=redirect to-ports=8080 src-address=10.10.0.0/16 src-address-list=clientes_activos dst-port=80 protocol=tcp
/ip proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8080
parent-proxy: 0.0.0.0
parent-proxy-port: 0
cache-drive: system
cache-administrator: "admin"
max-cache-size: none
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
/ip firewall filter> print
75 ;;; Acceso al Web-Proxy
chain=input action=jump jump-target=web-proxy dst-port=8080 protocol=tcp
76 X ;;; Log de accesos no autorizados al web-proxy desde el Dedicado
chain=web-proxy action=log in-interface=DEDICADO dst-port=8080 protocol=tcp log-prefix="DROP PROXY INVALID USER"
77 ;;; Drop de accesos no autorizados al web-proxy desde el Dedicado
chain=web-proxy action=drop in-interface=DEDICADO dst-port=8080 protocol=tcp
78 ;;; Aceptar conexiones entrantes desde la LAN al proxy
chain=web-proxy action=accept src-address-list=clientes_activos dst-port=8080 protocol=tcp
Well that is all, I hope you can help me
Bye
Rafael Lore
