problrm with real ip
hello
i have problem iwth real ip in mikrotik and fiber optic
i have ptp ip 213.244.65.202/30
gateway: 213.244.65.201
and i have range form real ip 213.244.85.192-199/29
i used ptp ip (213.244.65.202) in wan lan card and i use ip form range in lan card(213.244.85.192)
i used ip 213.244.85.194/29
gateway 213.244.85.192
I can’t connect to my computer from anthor network
i need nat configuration to connect my computer form anthor network
You should be using 213.244.85.193/29 in your LAN card. Set your computer’s default gateway to that address.
You do not need a NAT rule to masquerade 213.244.85.192/29.
