Newbie here, sorry to start my 1st topic with a problem..
Had no problems connecting to the RB2011 on Ether2. Ether1 connected to my LAN (with internet). Device got an internal IP-address, I did a firmware updated, rebooted.
All well, last firmware up and running (6.42 I believe).
Connected with WinBox and started the 1st-time configuration wizard. I did something wrong, after reboot my laptop couldnt get an IP address. Tried to reset the router, but..
And since then I am unable to connect to the router. I do the reset like I did before (button pressed after poweron and let go on blink of led). The thing is that “normally”
(in the beginning when it worked), the display also showed the IP address 192.168.88.1. Now there is no IP showing, just the user/pw. (admin empty).
Laptop with windows give an error that no DHCP server is available, and defaults to some weird IP address. Any help to continue is appreciated.
Did I trigger the backup firmware?
When I connect Ether1 to my LAN, it does get an IP address, but I am -ofcourse- unable to connect on that IP address.
