evince
November 3, 2014, 10:50am
1
Hi all,
I have a problem with 1 one my units. It is a RB2011UAS-RM running 6.20.
The CPU load is 100% and i can see the logging proccess using the whole cpu.
How can i stop it without rebooting the router? It is in production so i can not reboot it.
Thank you in advance.
Caci99
November 3, 2014, 11:31am
2
Go to /system logging and try disabling one by one the log rules until the CPU drops. Than analyze the one causing it.
evince
November 3, 2014, 11:33am
3
Thank you for your help.
I can not do this because i have a blank window when i display the logging settings, nothing appears
Caci99
November 3, 2014, 11:43am
4
even if you try for terminal? terminal might be a bit lighter than winbox, so it might be easier for the CPU to display the rules.
evince
November 3, 2014, 8:20pm
5
Yes, i get a timeout every command i write depending logging.
lambert
November 4, 2014, 12:01am
6
Can you get it to export the configuration via telnet or SSH connection? It may not export the entire config you may want to only ‘/ip firewall export’
If you can, are there any firewall rules which log packets? If so, try to disable the rule. If not just disable all entries under /system logging.
/system logging disable [find]
