Browsing products I tend to go for the same basic series with same OS and with minimal differences between versions so looking at switches I look at https://mikrotik.com/product/crs354_48g_4splus2qplusrm
and would very much like a 24G version of that one, but it seems there are more differences than just the amount of ports.
CRS112-8P-4S-IN is listed as Switch, not as Router?
CRS354-48G-4S+2Q+RM seems like a normal switch, but what is the difference between that and the 24 port Cloud Switch? Why is there not just a 24P version of it?
CCR1036-8G-2S+EM is listed as Router and not dedicated Firewall. I know you can configure rules for I/O in a router, but unless that works really smooth, I am not interested in that kind of micromanagement. Nor CLI for that matter. At all.
Well, I have a Zyxel firewall that has a “gazillion” predefined rules (USG60) so assuming CCR1036-8G-2S+EM is preconfigured and also updated in a similar way…?
As for PoE, well, I could have that in the 24p switch instead, it would be possible, I think. Can you jump PoE power from one patch connection to another?
As for 24P and 48P, it is because I need a switch in my server cabinet rack, the 48P is for my incoming patch panel… so the switches won’t be in the same place
Actually my “dated” RouterBOARD CCR1036-12G-4S have 60-70 “handmaded” rule, auto upload drop and edrop list among others, block malicious dns, etc. (I do not do now a full list of all)
(the first thing I do is clear completly the configuration, no default)
and protect near 4000 users and ping to 1.1.1.1 still 1~2ms
Can you jump PoE power from one patch connection to another?<<
no, power jack on the back for 24/48 on 8P model, and internal psu for 24PoE model
You left one important thing out: speed.
What is the needed routing speed?
What is the internet link speed?
What is the interconnection needed speed, between the switches? I imagine that the 48 and 24 ports switches would connect to different subnets, on different router ports. Am I right?
As Jack the Ripper used to say, lets do it by parts.
Router:
The only router I found with 4 PoE ethernet ports is the https://mikrotik.com/product/RB960PGS-PB. But its routing capabilities are very weak. One possibility would be to just buy some PoE injectors and use a “normal” router. Another would be to buy a cheap 5 port switch (https://mikrotik.com/product/RB260GSP) with PASSIVE PoE on 4 ports. Yet another would be to drop the requirement. Or, of course, You could buy another brand.
Dropping the PoE requirement for the router make easier to find it: Mikrotik sells from small itsy bitsy routers to monsters like the CCR1076. One of them will (probably) be the right one for You.
Quite impressive. Got 5 users and maybe 50 diff devices.
All in all, except for the CCR1036-8G-2S+EM, i could put together a package for about 1000€ which is reasonable for a Router with PoE + 24P switch + 48P switch + AP.
Can wait a bit with FW appliance
Current speed is max 1GB in Lan. No use to have faster due to I/O bottlenecks with my current drives. Have about 100Mb/s R/W via SMB3 and Jumbo Frames.
ISP Speed is 100/100MBit, can be upgraded up to 1/1GBit.
I only use one PoE as it is right now, don’t really plan on expanding that. can do without.
LTE? There is no LTE involved.
Also, I want to stick to ONE brand. Fed up with having 4 admin interfaces.
Nu subnets, well maybe one, if I connect each switch to its own port on Router, which would be recommended I guess. As mentioned, 100MBits is my overall internal data transfer rate, so that is enough. Better is bonus. I get higher speeds transferring data from a laptop with NVME SSD to a desktop with NVME SSD, but untested.
It is it hard requirement to have firewall and router separate and why? Just curious as most home and SOHO dont require it.
Is the extra expense a nice to have or a real need, in which case maybe I should put my hex before my CCR1009 LOL.
Yes and no. Short answer, Yes, I want it separate.
Long answer, performance wise i am concerned about the firewall being the same device as the router. Yes, it is a small network. Maybe I am being a bit paranoid, but the space where i will have this equipment is rather cramped and will reach high 40 degrees Celsius in summer and more if some device is under pressure from running both routing, dhcp, two lans, and firewall in the same device…
Having said that, I am not an expert, far from it, so if the general consensus is that this is not needed and I can run these services on the same physical device with no fear of stuff getting overheated or getting poor performance, well.
On the other hand I have a spare server with a late Xeon, 32GB DDR4 and some SSD’s that I can run PFSense on.
Ok. Although (as You can see below) the hardware is certified to high temperatures, I would try to run it no higher than 50 Celsius - ambient.
Router:
To 1Gbps internet I’d get an RB4011 (https://mikrotik.com/product/rb4011igs_rm). It’s certified to work up to 70 Celsius - ambient. I think it will be fine with your 40.
For Wifi if its a vanilla indoor access point you are looking for (aka a stable decent wifi 5 variant) I would select the tp link eap245.
I have not tried their latest wifi6 units yet eap 620 and 660 (too pricey).
Thanks but no thanks… as I mentioned, I rather keep all the products to one brand. A Cisco salesman will call me later today - I have some contacts via work - but tbh I don’t see that happen, my estimate indicates a 50% bigger price tag and their product lines are, imo, really hard to understand.
After some pondering I might be inclined towards this: https://mikrotik.com/product/RB1100Dx4 RB1100AHx4 Dude Edition
Not really sure about what benefits comes with the extra M.2 storage and how it helps The Dude, but a good network drawing/topology tool on the Router itself is not a bad thing.
The Dude needs some storage to deal with statistical data from controlled/monitored devices. While every ROS device comes with some permanent storage that storage comes with one or two problems:
As with all semi-conductor based permanent storage it has limited number of write cycles and the dude adds quite some. If wear and tear of built-in permanent storage crosses threshold, it can fail taking the ROS license with it … so replacement of built-in storage is practically a no-go option
with most devices built-in storage is too small to use it for much else than to hold ROS itself and router configuration
This is where additional (and replaceable) permanent storage comes into the picture. While external USB thimb drive could do as well, use of high-performance internal storage is preferred for professional use.
