Please recommend me hardware for outdoor 300m Point-to-Point connection.
I need connection with speed t least 500/500Mbit.
Important is also low latency because this connection will be used also for media streaming.
Please suggest system wireless device and antenna for this distance and speed.
I think you can’t reach this speed using MikroTik hardware. Maybe only using 80MHz bandwidth on super clear channel can get you closer to 500Mbps, but I don’t think it’s a reliable link, even on short distances.
I suggest you to take a look to Ubiquiti AirFiber24, SAF or Alcoma 17/24GHz.
Grab a pair of RB922UAGS-5HPacT-NM with an additional R11e-5HacD each.
Add your prefered pair of 5GHz dual chain antennas to the APs, choose your channels (1 for rx, 1 for tx, each 80 or 160MHz wide) and you should be good.
Nstreme dual is old technology, 5GHz-AC on MikroTik works good only on 802.11 plain protocol, not on nv2 and nstreme, so you won’t get the speed you see in the video.
In the video you’re seeing UDP speed test. With TCP it’s different.
You’ll have redundancy and speed.
But is very difficult to find 160MHz (80+80) clean spectrum to get these speeds, and your 5GHz neighbours won’t be happy with that
Also, to have good stability on AC you need a directional antenna with narrow beamwidth, like the new Dynadish or QRT 5 ac.
You have to lower the power a lot as your link is very short.
SXT has 28 degrees beamwidth, far too wide for a good AC link
I think for your bandwidth needs you should choose something else than 5GHz, even MikroTik with upconverter to 17 or 24GHz can be good if you want a cheap link
