Product suggestion
What products do I invest in?
I got 2 different ISPs that I want load balanced in the sense that I want to be able to decide that certain applications (youtube, netflix, certain hosts) go through a specific WAN unless its down or sometimes like in my case, veeeeeeeery slow.
I need 2 switches, one per floor. at the very least 4 ports per switch.
A wifi access point with the possibility to add another point later on for example in the guesthouse right outside. (would that be doable through wifi or does it need a cable connection out?)
Remote configuration and/or access is not very important but a nice addition if not too expensive. I always have computers locally to configure with etc.
I might get some PoE cameras in the future, might as well take that into account.
