Hello to all,
I unfortunately upgraded my userman router from 4.17 to 5.7
and I don’t have profiles assigned to 1400 users, there is no way to do it from console.
In the meantime, when creating profile limitations, I have discovered strange behaviour: userman web shows that limitation is valid for all weekdays,
while console shows only sun, mon, tue, fri & sat.
When I set in console to be valid for all weekdays, web shows only sun, mon, tue, fri & sat?!
What is correct? web or console?
Best regards, Petar
Since the V.5.7 user manager doesn’t have any formal resource, I have tested this configuration on V.5.6 http://forum.mikrotik.com/t/user-manager-configuration/51211/1
There is no different between 5.6 and 5.7 user manager.
test it and then I’m here to help you
There is a way to do assign profiles through console but it involves creating a master account for each profile. First I’d print a list of all the users by /tool user-manager user print file=filename. Then edit this file to be a filename.rsc place your commands as if running from console.
/tool usermanager remove name=Tinker
/tool user-manager user add name=“Tinker” password=“puppy” customer=“Convoy” registration-date=“sep/18/2011” first-name=“Tinker” last-name=“Pop” phone=“205-755-5555” location=“777 County Road 53 city, state 35555” email=“test@puppy.net” copy-from=“a_master_c_5gb”
/tool usermanager remove name=Tinker2
/tool user-manager user add name=“Tinker2” password=“puppy” customer=“Convoy” registration-date=“sep/18/2011” first-name=“Tinker” last-name=“Pop” phone=“205-755-5555” location=“777 County Road 53 city, state 35555” email=“test@puppy.net” copy-from=“a_master_c_5gb”
Then when done import file=filename.rsc all will be changed and updated at once.
When writing script file one line one command best to use notepad.
I have somewhat of a similar problem and hoping someone can help. When I create a limitation and set various rates, then I move to the next limitation and setup different rates, then open various limitations, some lose all their settings and display different values from different limitations.
I tried Chrome, Safari, Internet Explorer and Firefox. I tried to clear cache and do a full reload. No luck.
