profile on radius
We are using freeRadius to autenticate the pppoe users. now we would ike to assign via radius also the profile of the users. how can it be done ? I cannot find it on the attributes…
Give us some more info, as to what you are tring to do. Are you whating to set up diff relms as to what type of IP public or private or bandwitdh
we would like to give different services to our clients.
client A has a profile A and their traffic is going through a firewall rules on rule forward /ppp …
same thing for client B
this is like we are doing it with pppoe right now, assigning a different profile to customers A profile A, B..B
but we use local database on MK
now we are shifting to radius, user7pw autentification works fine, but no idea on how we can giv eto the mk the profile indication per each user
hope this is a bit more clear
maybe filter-id is like ppp profile in the local database
Filter-Id - firewall filter chain name. It is used to make a dynamic firewall rule. Firewall chain name can have suffix .in or .out, that will install rule only for incoming or outgoing traffic. Multiple Filter-id can be provided, but only last ones for incoming and outgoing is used. For PPPs - filter rules in ppp chain that will jump to the specified chain, if a packet has come to/from the client (that means that you should first create a ppp chain and make jump rules that would put actual traffic to this chain). The same applies for HotSpot, but the rules will be created in hotspot chain
