Propagate routes for customers BGP peer
Gentlemen, I am a layman in the subject.
I am a provider and a client will connect via BGP with our router.
Have climbed the session but on his side he only receives prefix-count = 1.
How could we get our table full and send to peer client?
sorry for my english
Do you speak eBGP to your providers?
Do you get full tables from your providers, or just default routes (0.0.0.0/0)?
Does the router which speaks eBGP to your customer also speak iBGP to your router which speaks eBGP to your provider?
On the router which speaks to the customer, try:
/ip route print where bgp
Does that return 1 route? Some routes? Or more that 100,000 routes?
Do the same on the router which speaks to your providers, if that router is Mikrotik.
Yes, eBGP, full tables.
Let’s use the same router that does eBGP who is receiving full routing to establish another eBGP to our customer
We’re getting more than 500k routes.
I want to propagate the same routing table of the main router to the client.
Hi..
Could you please draw topology of your connectivity and also send me the export of routing configuration
/ routing bgp export
This way I can undrestand how to figure out your problem and fix it..
Best regards
Ali Sami
MikroTik Authorize trainer
MTCNA-MTCTCE-MTCWE-MTCRE-MTCINE
