Hello community,
I’d highly appreciate if someone could suggest on possible optimization for the following case.
Given task: Mikrotik hAP ax3 in front and Exim SMTP server behind it. Routing is done using dstnat rule, here’s the rules chain:
add action=dst-nat chain=dstnat comment=“Web/mail server port forwarding” dst-address-list=WAN_IP dst-port=80,443,25,465,993,143 in-interface-list=WAN protocol=tcp to-addresses=192.168.10.110
add action=accept chain=srcnat out-interface-list=LAN src-address=192.168.10.80-192.168.10.99
add action=src-nat chain=srcnat comment=“LAN NAT masquerade” out-interface-list=WAN src-address=192.168.10.0/24 to-addresses=<WAN_IP>
add action=src-nat chain=srcnat comment=“Guest NAT masquerade” out-interface-list=WAN src-address=192.168.11.0/24 to-addresses=<WAN_IP>
Comments
192.168.10.1 - Internal IP of Mikrotik router
192.168.10.110 - Internal IP of SMTP server
192.168.10.80-192.168.10.99 - pool of VPN clients IP
WAN_IP - external static IP or router
Problem description: with current settings the average connection time to SMTP server is about 5-6 seconds and it is too long for some SMTP clientsm hence they interrupt the connection with timeout. With try and errors method it was detected that with introduction of NAT rule
add action=masquerade chain=srcnat comment=“Masquerade all other LAN traffic” out-interface-list=LAN
the connection time reduces to only tenth of seconds, but the drawback that of course extrernal client’s IP are masked with router’s internal IP:
Example:
Here’s the result of the test when rule “Masquerade all other LAN traffic” was disabled
2025-02-28 00:59:07 H=keeper-us-east-1d.mxtoolbox.com [18.209.86.113] sender verify fail for <supertool@mxtoolboxsmtpdiag.com>: all relevant MX records point to non-existent hosts
2025-02-28 00:59:07 H=keeper-us-east-1d.mxtoolbox.com [18.209.86.113] F=<supertool@mxtoolboxsmtpdiag.com> rejected RCPT <test@mxtoolboxsmtpdiag.com>: relay not permitted
And here - when enabled
2025-02-28 01:00:21 H=<my.router.name> (keeper-us-east-1d.mxtoolbox.com) [192.168.10.1] sender verify fail for <supertool@mxtoolboxsmtpdiag.com>: all relevant MX records point to non-existent hosts
2025-02-28 01:00:21 H=<my.router.name> (keeper-us-east-1d.mxtoolbox.com) [192.168.10.1] F=<supertool@mxtoolboxsmtpdiag.com> rejected RCPT <test@mxtoolboxsmtpdiag.com>: relay not permitted
Can you suggest any best practice to keep the connection speed and remain the client’s original IP addresses?
