Can I get a bit of advice for configuring my optimal OSPF settings?
I have attached a diagram of my network topology. It’s basically a series of point to point, back to back wireless links that are all bridged together except for one link which is a separate network. At each site (branch) there is a LAN that is not bridged with the RBs. It’s information is redistributed via OSFP. It’s all working fairly well except that I get a bit of random downtime that does not correspond to times the individual links have gone down. I felt like perhaps my dead timer settings were incorrect so I changed them from 40s to 4000s since it did not seem necessary to declare a router dead since there is no alternative route.
But I started wondering if I’m just doing this all wrong and there is a better way to configure this arrangement.
Most of the wireless links are bridged with WDS except the first and last links which are just bridged.
The 750G units at each site bridge the radios together but do not bridge the LANs. They advertise the LANs throughout the OSPF routing scheme. Every device in this diagram except the Sonicwall participates in OSPF. The devices in the blue and red areas are set to PTMP mode rather than broadcast as I found that broadcast produced terrible results.
The Sonicwall is the default gateway for the HQ LAN, does not participate in the OSFP scheme, and has a static route which forwards all the relevant IP ranges to the HQ mikrotik for routing to the appropriate location. It is all working well, I just want to figure out how to improve.
Any advice would be appreciated. (See attached.)
OSPF Network.pdf (106 KB)
