I have the problem described in other posts where some of the pages load and others don’t. I also seen where they mention changing the MTU. I looked at the settings in the modem and it has 1540 for MTU. My question is how do we know what to put on the RB to make it work because the RB won’t even except a setting of 1540. Also is this the only other setting that I need to worry about because I already have the PPPoE client part working.
Packet Information
VPI / VCI
In Errors
In Discard Packets
In Non Unicast Packets
In Unicast Packets
In Octets
Out Errors
Out Discard Packets
Out Non Unicast Packets
Out Unicast Packets
Out Octets
do you change this setting in winbox under interfaces and then under pppoe interface or do you put a rule under mangle.
since my dsl modem has a setting of 1540 and 20 percent is is what they recommend knocking off then 1232 would be correct. to be honest I have never had to change mtu or use a mangle rule before so this is all new to me.
thanks
I just talked with verizon and they are going to send me a new modem to try since the mtu shows 1540. They think something is wrong because of this. I will update on the 22nd. Thanks all for your help.
This works in my office but not at the customers site so I am stuck buying a linksys or someother such router instead of using the Mikrotik like I wanted.
