Proper Shutdown - 2.9.30
Hi, I’m trying the 2.9.30 version and in a moment the router reload:
11:39:29 system,error,critical router was rebooted without proper shutdown
The same configuration runs in another with 2.9.17 version and works fine.
This is the watchdog config in boths:
[admin@FW1] system> watchdog print
reboot-on-failure: yes
watch-address: none
watchdog-timer: yes
no-ping-delay: 5m
automatic-supout: yes
auto-send-supout: no
What could it be ?
you have answered yourself. you have enabled watchdog timer :slight_smile: why ? disable all watchdogs and see if it helps.
Normis, thanks but the watchdog in the other mikrotik is active (with 2.9.17 and more power hardware).
Could it be other thing or only wathdog ?
Thanks a lot.
Regards
why don’t you disable and see ?
Ok Normis, I’m going to do that.
Thanks a lot
