Good afternoon,
Yesterday I finally switched over from the ISP-provided router to the RB951-2n with the ISP one as a modem.
Almost everything seems to be working fine - except for my game servers.
Taking as an example Minecraft (since the effects of this were dramatically ovbious in-game):
-Player A does something. Server sees player doing something and so do clients local to the server. BUT remote client (through the internet) doesn’t see any changes.
I fired up WireShark and I’m seeing these sort of things in the hundreds:
26827 100.950620 81.xx.xxx.xxx 192.168.88.139 TCP 54 [TCP ACKed unseen segment] 51588 → 25565 [ACK] Seq=1534 Ack=2216925 Win=1360 Len=0
26828 100.950628 81.xx.xxx.xxx 192.168.88.139 TCP 54 [TCP ZeroWindow] [TCP ACKed unseen segment] 51588 → 25565 [ACK] Seq=1534 Ack=2218285 Win=0 Len=0
Setup is as follows:
ISP modem>RB951-2n>TP Link Archer C2 in AP mode
The computer that sees this traffic (‘server’ in question) is connected to the RB951 directly, all other LAN clients connected to the C2. Internet clients obviously through the internet
Configuration below:
add admin-mac=D4:CA:6D:F2:32:CD auto-mac=no mtu=1500 name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=spain disabled=no \
distance=indoors mode=ap-bridge ssid=*** wireless-protocol=802.11
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] name=ether3-voip
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-AP
set [ find default-name=ether5 ] auto-negotiation=no master-port=\
ether2-master-local name=ether5-Server
/interface pppoe-client
add add-default-route=yes default-route-distance=1 disabled=no interface=\
ether1-gateway max-mru=1460 max-mtu=1460 name=pppoe-out1 password=adslppp \
service-name=Telefonica use-peer-dns=yes user=***
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
wpa-pre-shared-key="***" wpa2-pre-shared-key=\
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.88.130-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge-local lease-time=12h name=\
default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/ip settings
set accept-source-route=yes
add address=192.168.88.1/24 interface=ether2-master-local network=192.168.88.0
/ip dhcp-server config
set store-leases-disk=immediately
/ip dhcp-server lease
add address=192.168.88.130 client-id=1:78:d3:8d:3:fa:2e mac-address=\
78:D3:8D:03:FA:2E server=default
add address=192.168.88.139 client-id=1:94:de:80:2:55:5c mac-address=\
94:DE:80:02:55:5C server=default
add address=192.168.10.0/24 dns-server=192.168.88.1 gateway=192.168.10.1 \
netmask=24
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,208.67.222.222
/ip dns static
add address=192.168.88.1 name=router
add action=drop chain=input comment="Input drop invalid" connection-state=\
invalid
add action=accept chain=input comment="Allow state new" connection-state=new \
in-interface=all-ethernet
add action=accept chain=input comment="Allow state established" \
connection-state=established
add action=accept chain=input comment="Allow state related" connection-state=\
related
add action=accept chain=input comment="Allow pings" protocol=icmp
add action=drop chain=input comment="Input drop catchall" dst-address=\
!192.168.88.1 src-address=!192.168.88.130
add action=drop chain=forward comment="Forward drop invalid" connection-state=\
invalid
add action=accept chain=forward in-interface=pppoe-out1 protocol=udp src-port=\
25565
add action=accept chain=forward in-interface=pppoe-out1 protocol=tcp src-port=\
25565
add action=accept chain=forward comment="Forward new" connection-state=new
add action=accept chain=forward comment="Forward established" connection-state=\
established
add action=accept chain=forward comment="Forward related" connection-state=\
related
add action=drop chain=forward comment="Drop catchall"
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=pppoe-out1 to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-port=25565 in-interface=pppoe-out1 \
protocol=tcp to-addresses=192.168.88.139 to-ports=25565
protocol=udp to-addresses=192.168.88.139 to-ports=25565
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip proxy
set cache-path=web-proxy1
add disabled=yes distance=1 gateway=192.168.1.1
/ip service
set telnet disabled=yes
/ip upnp
set enabled=yes
/system clock
set time-zone-autodetect=no
/system clock manual
set time-zone=+01:00
/system leds
set 0 interface=wlan1
/tool mac-server
add interface=ether2-master-local
add interface=ether3-voip
add interface=ether4-AP
add interface=ether5-Server
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
/tool traffic-monitor
add disabled=yes interface=ether1-gateway name=tmon1 threshold=0
I’ve exhausted my ideas now and I was hoping someone could have a look!
Thanks in advance for your time
