Hi, I have read for “Protected bootloader” to prevent reset devices.
SXT lite is not compatible?
Is any way to prevent reset devices in SXT lite 5? Only knowing the user and password, disabling reset buttons (hole and push button)
Thanks!!
Thanks!!
You’ve read it wrong, please read it again here. The only purpose of protected bootloader is to protect the configuration and files on your device from unauthorized access even if your device is physically accessible to a trespasser. Protected bootloader does not prevent a device from being reset, just makes that process (slightly) harder (longer).
Oh, I see, then it´s good for me too, but my question is… is possible to install in a SXT Lite 5
Thanks for your clarification.
Just set the protected mode from RouterOS console:
/system routerboard settings set protected-routerboot=enabled
Hi, with this command I get “01:45:34 echo: system,info,critical Current RouterBOOT does not support this feature”, need to upgrade ROS and firmware?
ROS is 6.37.1 mipsbe on a SXT Lite 5
Thx!!
Hi, then it´s not compatible?
