protected-routerboot ON RB951Ui
[admin@MikroTikFA] /system routerboard> print
       routerboard: yes
             model: 951Ui-2HnD
     serial-number: **************
     firmware-type: ar9344
  factory-firmware: 3.19
  current-firmware: 3.33
  upgrade-firmware: 3.33
17:19:16 echo: system,info,critical Current RouterBOOT does not support this feature
but it works with SXT LTE
also on RB2011
[amir@MikroTikFa-Foroozani] /system routerboard> print
                ;;; Current RouterBOOT does not support this feature
       routerboard: yes
             model: 2011UiAS-2HnD
     serial-number: xxxxxxxxxxx
  factory-firmware: 3.22
[amir@MikroTikFa-Foroozani] > system routerboard settings print
            baud-rate: 115200
           boot-delay: 5s
       enter-setup-on: any-key
          boot-device: nand-if-fail-then-ethernet
        cpu-frequency: 600MHz
        boot-protocol: bootp
  enable-jumper-reset: yes
  force-backup-booter: no
          silent-boot: yes
RB2011 v6.39
