So I know most of the outdoor equipment is built to withstand the ‘typical’ elements, what are you guys doing for installs near the ocean?
The salty air near the ocean seems to be able to corrode even stainless steel over time. Are you guys dressing your equipment with any products to add an additional layer of protection?
Just to put it in to context, I’m referring to items like a Netmetal 5 which has a small opening for the antenna cables to get to the radio interface and the interface point for the mANT.
Caulking… a spray that provides a thin layer of protection? Thoughts?
If it is any less the 316 grade then even stainless steel will corrode in salt environments.
I don’t have the NetMetal, but I can’t see how caulking with something like silicon would hurt. Or wrap the area around the hole with some coax sealant tape.
you could use the Netmetal and just like the above poster suggested, spray it with something, like WD40, silicone or anything really. the Netmetal is fully sealed, and once the antennas are attached, it will not matter what you coat it with.
netmetal can be used with the cover taken off, because the antenna connectors are isolated too (rubber seals on both sides), the cover is just an extra layer of protection
