Protocols
Hi
I have a problem with set a protocol for monitor and see it’s graph . for example : automatically HTTP protocol added and drown graph ,but when I want to set a TCP/port no (TCP/3050) for monitoring, I can set only connect or first send/receive.
What should I do to monitor send and receive continuously
thanks
Hi arsalan,
I believe you are thinking of the HTTP probe can be used to graph only the http protocol. What it does is ask a server for a web page. The Dude only asks devices how they are doing. It does not listen to traffic in the port monitor sense. It reads SNMP counters to show traffic.
You could look into setting up NER to record all the traffic for a given network then you could view graphs of any protocol you like. It runs on Linux.
NER is opensource. NER download NER forum
SD
HI my friend,
SNMP protocol work only on win XP ,But I want run on Win2003
thanks
A guide to setup snmp in windows… includes 2003
http://www.mydigitallife.info/2007/11/01/install-and-enable-snmp-service-in-windows-xp-vista-and-2003/
