Hello, everyone. I’m trying to set up a VPN connection using ProtonVPN on a MIkrotik RB960PGS. I followed this https://protonvpn.com/support/wireguard-mikrotik-routers/ official guide but it puts everything under the VPN and it worked but I only need two TV’s under this VPN. I already tried to modify it unsuccessfully to fit my scenario with no results, traffic continue as usual.
I’m going to post here what I did but pretty sure is far away from the solution. Can someone please help me out?
# may/19/2024 09:54:00 by RouterOS 7.7
# software id = AMBP-KK9N
# model = RB960PGS
# serial number = ****************
/interface bridge add admin-mac=xx:xx:xx:xx:xx:x auto-mac=no comment=defconf name=bridge
/interface wireguard add listen-port=13231 mtu=1420 name=wireguard-inet
/disk set usb1-part1 parent=usb1 partition-offset=512 partition-size="31 029 460 480"
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik
/ip hotspot profile set [ find default=yes ] html-directory=hotspot
/ip pool add name=dhcp ranges=192.168.10.10-192.168.10.254
/ip dhcp-server add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
/ip neighbor discovery-settings set discover-interface-list=LAN
add interface=wireguard-inet list=WAN
/interface wireguard peers
add allowed-address=192.168.10.13/32,192.168.10.12/32,192.168.10.14/32 endpoint-address=66.90.82.26 endpoint-port=51820 interface=wireguard-inet persistent-keepalive=25s public-key="*****"
add address=192.168.10.1/24 comment=defconf interface=bridge network=192.168.10.0
add address=***********/24 interface=ether1 network=***********
add address=10.2.0.2 interface=wireguard-inet network=10.2.0.0
/ip dhcp-client add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.10.18 block-access=yes client-id=************* mac-address=44:CB:8B:4B:A9:5C server=defconf
add address=192.168.10.197 client-id==************* mac-address=************* server=defconf
add address=192.168.10.196 client-id=************* mac-address=************* server=defconf
add address=192.168.10.142 client-id=************** mac-address=************* server=defconf
add address=192.168.10.15 client-id=************* mac-address************* server=defconf
add address=192.168.10.2 client-id=************* mac-address=************* server=defconf
add address=192.168.10.12 client-id=************* mac-address=************* server=defconf
add address=192.168.10.13 client-id=************* mac-address=************* server=defconf
/ip dhcp-server network add address=192.168.10.0/24 comment=defconf dns-server=192.168.10.1 gateway=192.168.10.1 netmask=24
/ip dn set allow-remote-requests=yes servers=10.2.0.1,1.1.1.1
/ip dns static add address=192.168.10.1 comment=defconf name=router.lan
add action=drop chain=input comment="defconf: drop invalid" connection-state=nvalid
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=wireguard-inet src-address=192.168.10.13
add action=masquerade chain=srcnat out-interface=wireguard-inet src-address=192.168.10.12
add action=masquerade chain=srcnat out-interface=wireguard-inet src-address=192.168.10.14
/ip route add disabled=no distance=1 dst-address=66.90.82.26/32 gateway=10.2.0.1 pref-src="" routing-table=main suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment= "defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock set time-zone-name=America/Bogota
/system routerboard settings set auto-upgrade=yes
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
My network is very basic but I have a lot of devices. A cablemodem in bridge mode with static IP —> Mikrotik router → Unmanaged Switch ----> Wireless AP
