after running the command from a terminal “/ip proxy cache-contents print file=/secondary-master/qwe”
I’ve got a really big (416M) file on my external attached hdd, so I copied it to my linux box though ftp, for simple statistics
generation. I’ve noticed from my stat results that some uri-s are repeated in much more systematic way than it normally should, I mean every 146th line was the very same as one ‘block’ before…
This kind of repetition doesn’t start at the beginning of the file, only after a few hundred lines.
I’ve repeated the dump for 3 times, and I’ve got the same bad content, while Winbox’s Cache Contents shows a lot more uri’s than the dump.
I think this is a ROS problem, the proxy is working perfectly with a lot of rules, serving 2 isp connections for 12 subnet, without any problems at big traffics.
has anybody noticed something like this before?
thanks!
